The accumulation of ashes on the magnets has been a growing problem. Living on an iron planet, everything that burns contains iron. A snapping mechanism would be nice. Maybe there could be another spring mechanism. The easiest solution is to never destack the booster. Empty the ashes & replace the incense sticks with the booster stacked. It could be printed in 1 piece to make accessing the full stack easier or it could use more permanent, non magnetic farsteners. A brush would be required to clean it when stacked but it already requires a brush to clean the magnets. A test might be gluing the full stack.
Helas, it's not practical to change incense with the booster stacked. It would need a tool. Emptying the ashes would make a mess. There are twisting tabs which could take less room than magnets.
No more melting & no more sticks have burned to the bottom so far, but some have gotten close & they always burned to the bottom before the starship.
lion mclionhead
