This one has a notch allowing the rocket to lock by rotating. It's the most convenient of all tab designs & doesn't accidentally release.
The thrust structure was cut open to allow ash to be poured out without destacking. It still doesn't all come out without destacking & it's not as visually accurate. It still has to be destacked to change incense sticks.
Periodically, ashes fell outside the thrust structure so that was a fail. It needs to be a complete circle.
lion mclionhead
