I added a nameplate to the back, just to make the model more realistic. There is a thin part named NamePlate that I 3D printed. There is also a file named NamePlate to print on thick card stock. Glue the paper name plate to the 3D name plate. I colored the side of this assembly with silver paint and then glued this to the back of the DSKY. To make it even more realistic, I dug up four small screws with rounded heads and cut the heads off and glued them to the four corners of the name plate.
