PAL - NTSC auto switch for PSONE LCD
Use your PSONE LCD with both PAL and NTSC sources - games
2k views
0 followers
This mod changes the main LCD panel controller signals to switch automatically between PAL and NTSC timings based on the input frequency.
Beware:
It should work for both NTSC and PAL LCDs but my model was NTSC, so different modifications may be needed for PAL.
It does not change the color carrier in any way, so this works only for RGB video, not composite (it works, but the image is B/W in the non-native standard).
I will add firmware source code and details about how it works...
PAL-NTSC-DET.production.hex
This is the hex file for the microcontroller
hex - 1.87 kB - 06/26/2022 at 21:04
Download
  • 1 × PIC16F18313
  • 1 × 6 PIN MALE HEADER
  • 1 × 6 PIN FEMALE SOCKET OR HEADER
  • 1
    Remove the speaker covers and remove screws
    Remove the speaker covers (they are just glued) and the top rubber caps and then remove the underneath screws.
  • 2
    Open the round case
    Open the round case with a credit card, your nails or just something soft to avoid damaging the case
  • 3
    Remove the PCB screws
    Remove the screws, but don't remove the PCB from where it's sitting, we just need to lift it a little bit from the left to put our PCB bellow.
View all 10 instructions
