I have posted pdf versions of the project description, details, and project logs in the files section of this project, along with a pdf version of the original source code for the UCSD p-system compiler for a more pleasant reading. So much more fun if you are viewing with a tablet. Additional source files are available on GitHub and in standard form and will be regularly updated as things continue to make progress.
I read that CP/M has now been officially liberated. So now it might be worthwhile to consider adding CP/M compatibility, instead of the original UCSD p-system file system. Lots to do.
In the meantime: Enjoy!
I think I will completely rewrite the tokenizing function INSYMBOL even further, so as to, hopefully, completely eliminate all case statements, which of course get replaced with switch statements in C/C++. Doesn't this look much nicer?
namespace pascal0
key_info operators[] =
key_info(":=",BECOMES,NOOP),
key_info("(*",COMMENTSY,NOOP),
key_info("{",COMMENTSY,NOOP),
key_info("*)",SEPARATSY,NOOP),
key_info("}",SEPARATSY,NOOP),
key_info("<>",RELOP,NEOP),
key_info(">=",RELOP,GEOP),
key_info("<=",RELOP,LEOP),
key_info("..",COLON,NOOP),
key_info(".",PERIOD,NOOP),
key_info(":",COLON,NOOP),
key_info(";",SEMICOLON,NOOP),
key_info("^",ARROW,NOOP),
key_info("[",LBRACK,NOOP),
key_info("]",RBRACK,NOOP),
key_info("(",LPARENT,NOOP),
key_info(")",RPARENT,NOOP),
key_info(",",COMMA,NOOP),
key_info("+",ADDOP,PLUS),
key_info("-",ADDOP,MINUS),
key_info("*",MULOP,MUL),
key_info("/",MULOP,RDIV),
key_info("=",RELOP,EQOP),
key_info(">",RELOP,GTOP),
key_info("<",RELOP,LTOP),
key_info("\'",STRINGCONST,NOOP),
key_info("",OTHERSY,NOOP),
And thus another long chain of case statements bites the dust.
