![](https://cdn.hackaday.io/images/5920221660789429880.png)
Well, you know what I mean. I mean my first Pascal Program with the new compiler! Sort of. In any case, I am finally generating something that at least looks like a binary image, even if there are still quite a few bugs - and even that should be taken as an understatement. Yet I am VERY close to having a p-code image that might run on genuine Apple II hardware, or on an emulator - or, wouldn't it be nice to have Apple II GS emulation on the Parallax Propeller P2? Even though I will need to write a p-code interpreter for that, that should be pretty easy by comparison.
There is after all that other story about the other three bears. The one that says that if a bear ever confronts you you should consider the following advice: If there bear is brown, lay down. If the bear is black, fight back. If the bear is white, good night! Remember, it's your life, and quite possibly your death.
As I said, there is still lots of work to do, and lots of bugs, so this code is still too preliminary to assign a version number. But you can find the code on GitHub anyway. BE VERY AFRAID,
