Expand to 5x4 array of midi buttons
A project log for Raspberry Pi Pico 4xN Midi Arcade Button Box
Mashup of 2 Adafruit projects to make a 4x4 (4xn) Arcade Button/Led MIDI Device
jerry-isdaleJerry Isdale • 07/02/2022 at 06:27•0 Comments
Today we wired up a total of 5 arcade button boards with 30mm buttons, and extended the code to support it as total of 20 midi buttons.  The new code is in code_QTMidi_5x4.py in the github archive.
Here's my blond assistant checking over the connections of the full 20 button setup.
Next up will be making one set of 4 buttons be built in bank switchers. Pressing one of these will switch to a different button-to-note mapping.
Then we got the weekend  to build the housing and hook it up to Resolume so it selects 64 video clips.
