LVDS LCD Hacking with FPGA
Reverse engineering approach to reuse LVDS LCD panel with use of the FPGA
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
For first serious FPGA project I had to wait a while for laptop LCD. I scored quite good LCD panel which had enormous resolution for my first try. It took many hours just to turn the display on with white screen.
Now I can display any pattern on the screen. The real limit is really now only the lack of external RAM. But for my first experiments the Lattice MachXO2 will do the job.
Now I can display any color on any pixel. There is not that issue with blue color that I mentioned in the second video. I have made code for seven-segment digits that will be used as clock for now. Later I plan to display some small color images from internal ROM and later I would play with small VGA camera.
