Introduction
The current time is indicated by the position of the light. The lights are divided into three groups, respectively hours, ten, a fraction, read also more consistent with the habit, several dozens of minutes. The 12-hour system is adopted for easier reading.
At the same time, a backlit Logo area is set on the left side, which can be lit by a breathing lamp, giving a different kind of vitality.
There are 7 touch buttons at the bottom, which is the simplest electronic organ. There is also a function switch button behind, click, it will become an 8bit music box, you can save a few special music, such as -- Canon.
hardware
- WS2812 LED, which can be coded to 65535 colors (not actually used that many)
- PicoBit is a super mini development board based on raspberry PI RP2040, provided by endless fun team (https://talk.quwj.com/), thanks to the team leader Spoony
- Passive buzzer playing music artifact, 80's red and white machine main music output equipment!
- Touch IC SC09B experience is good, simple peripheral circuit.
Function
- There are two ways to express the display time. One is that only the corresponding time position is on, as shown in the figure below:
The other is a Light up to the current time, as shown below:
- Simple electronic organ click the corresponding touch button, you can play the corresponding scale, you can play a little star, two tigers and so on.
- On the 8-bit music player, I saved the brief score of several songs and played different songs by clicking different touch buttons. My favorites are Canon and BadApple.
Other
Picobit Clock https://www.bilibili.com/video/BV1TZ4y1i7Uu/
PT - Clock creative Clock https://www.bilibili.com/video/BV1gF411F76L/
PTIdea
ted
Michael Möller
Yakroo108
