Hackaday.io Hackaday.io
Sign up Log in
Home Circuit Finder with 2 NodeMCU's
Using a couple of Nodemcu's to find out what circuit a plug receptacle is connected to.
thinklearndoThinkLearnDo
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
182
0
1
0
Team (1)
  • thinklearndoThinkLearnDo
Join this project's team
  • Code and a quick howto
hardware
ongoing project
NodeMCU Circuits
This project was created on 06/30/2022 and last updated 4 years ago.
Description
My Dad was having to deal with finding out which plug receptacle is connected to which circuit at work. He came up with a simple idea of using NodeMCU's to help solve that problem. This is the result.
One NodeMCU acts as an access point and listens for UDP broadcasts from the other NodeMCU which connects to the access point. It sends out UDP packets 10 times a second. Once the client stops sending packets for 1 second, the onboard LED on the server turns off, indicating the correct circuit breaker has been found.
Project Logs
Collapse
  • Demo video
    ThinkLearnDo • 07/01/2022 at 00:44 • 0 comments
    Here's a quick demo of it in action:
View project log
Log In/Sign up to comment
Sign up with Github
OR
Build an ON-OFF circuit using MOSFET
Project Owner Contributor
Touch ON-OFF Switch with UTSOURCE Service
naman-chauhanNaman Chauhan
The 555 as circuit sculpture.
CS 555
mabe42MaBe42
Radio Jammer
CALIBRO22 - FM Radio Deauther Keychain
nbreakfastnbreakfast
Hackaday Prize 2019
Here I made exact working replica of 555 IC by using transistors.
Discrete 555 Using Transistors
discrete-electronics-guyDiscrete Electronics Guy
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Home Circuit Finder with 2 NodeMCU's", please tell us the reason.
Send message
Remove Member
