Initial investigations to see if we are barking up the wrong tree.
Assumptions
- SAT density: 1.46g/CM3
- SAT latent heat of fusion: 0.073Kwh/Kg (264kJ/KG low end 289KJ/KG high end)
- 60% SAT to water solution (volume?)
- ABS thermal conductivity: 0.1 W/m/K (SAT thermal conductivity not modeled ABS wall only)
- SAT temp 58C
First test pipe ( to be built)
- 43mm OD 1.5mm wall ABS 1m long
- 4.16Kg sodium acetate 1.91Kg water 6.07Kg total
- 0.30Kwh
- heat output @18C room: 257w
- heat output @20C room: 244w
- estimated 1h runtime
Full size pipe
- 75mm OD 65mm ID 5mm wall ABS 1m long
- 11.55Kg SAT, 5.31Kg water, 16.86 total
- 0.84Kwh
- heat output @20 room: 166w
- heat output @ 18 room: 175w
- estimated 4h runtime
