Raspberry Pi Guitar Amplifier
Guitar Amplifier and effects made with Raspberry Pi and reused Vox amplifier case
Public Chat
I took a Vox VT20+ amp I had that had stopped working, took out everything but the speaker and wired in a Raspberry pi, power supplies, class D amplifier, potentiometers (to set the effect levels), leds, and even VU lights on the front. I used Python and the pyo audio library to do the effects and the GPIOzero module to read the pots.
I built this amp in partnership with my guitar teacher. I taught him Python and a little bit of the electronics and he picked out the effects and how we adjusted them. He is building his own also. Maybe I can get him to post!
Ben's build in a box
JPEG Image - 1.69 MB - 08/12/2022 at 20:39
Preview
MCP3008 wiring
JPEG Image - 1.94 MB - 08/12/2022 at 20:39
Preview
MCP3008 wiring
JPEG Image - 1.74 MB - 08/12/2022 at 20:39
Preview
IMG_4982.mov
photo of ben's build
quicktime - 31.41 MB - 08/12/2022 at 20:27
Download
IMG_4844.HEIC
heic - 1.98 MB - 08/12/2022 at 20:27
Download
View all 14 files
  • 1 × Raspberry Pi 3 Pi 2 should also work or 4
  • 1 × Cabinet I used old Vox cabinet
  • 1 × speaker, 8ohm or 4ohm
  • 1 × fanless power supply 24v I used Meanwell RT50D
  • 1 × fanless power suppy 5v I used Aiposen 5V 25W
View all 19 components
  • Looper Troubles and Solution
    dsagman • 10/20/2022 at 15:31 • 0 comments
    So I got my looper working. But not without pain, pain, pain. And not just from a guitar string snapping and ending up sticking out the back of my hand. You know when you have everything working and you go to do the final power on and it doesn't work? Yes. That's what happened.
    Long story short, I believe that when I attached my homemade pedal with a six foot guitar cable (cause it looked boss) I brought the associated GPIO pin low because the signal just faded out over that length of thick wire. Oscilloscope testing later proved that to be the case, but that would be a few days later.
    At first I thought I had maybe disabled one too many system services in my quest for performance and removing noise artifacts. That was a dead end, but I spend hours reinstalling drivers such as triggerhappy, rfkill, journald, which were completely unneeded.
    I hadn't realized that the audioinjector card used the I2C gpio pins for initial setup. So when I tried to use pin 2 for my pedal, the card failed to initialize. But it had worked with a short bit of wire hooked to a switch, just not the long wire!
    An option now was to use a shift register to open up more GPIO pins, but ugh, that sounds like real work. Maybe someday, but for now what I did was move the led for the looper to pin 2 (a short wire) and for the looper pedal I rewired to drive 1.5 volts with a hacked in voltage divider on the cable.
    That looks like this:
    I just soldered the resistors directly to the wires heading into the GPIO and wrapped with some heat shrink tubing. Not idea, but it works now.
    And here's my what it looks like:
    The wires labeled +3v and GND are the ones with 10K resistors hidden away beneath the black shrink tubing.
  • looper pedal in progress
    dsagman • 10/17/2022 at 01:25 • 0 comments
    Super janky wooden pedal for looper switch in the works.
  • Code updated
    dsagman • 10/10/2022 at 23:09 • 0 comments
    I updated the code on github and the instructions on the looper. I have to make a pedal next. I expect the router will see some use as I want this as janky as possible and I will likely just hock out a chunk of 2x4 to house the switch and connector.
  • Code updated
  • LOOPER Working!
    dsagman • 10/10/2022 at 02:57 • 0 comments
    I've gotten the loooper working. Video here:
    I have started updating the documentation and have to upload revised code, and will do so in the next few days.
    It was a journey, and I managed to solder the lone LED required incorrectly multiple times.
  • Can't Get Audio Looping Working
    dsagman • 08/23/2022 at 14:15 • 0 comments
    To catch up, I've figured out how to:
    -Trigger a record, loop, wait states using a button connected to a GPIO pin.
    -Record the audio during the record phase.
    But I cannot play the audio during the loop. I've got it working on my laptop, but on the PI, I get a SIGSEGV error from pyo's SfPlayer method.
    I tried a bunch of different workarounds, which have not worked. I tried playing the audio via a different program, such as aplay, which does work in isolation. But it fails when trying to play with the main program because the two processes: pyo and aplay both want to lock the audio to them. And only one can win, ala Highlander.
    Sooo, I suspect it may work if I use Jack as the audio backend instead of the default portaudio. But to do that, I have to compile pyo from scratch with Jack support enabled. I've tried twice and am not having luck with python recognizing the rebuilt pyo. I am trying again. Fingers crossed.
  • Ben's Build
    dsagman • 08/23/2022 at 14:10 • 0 comments
    Ben is making progress on his build.
  • Setting up ALSA, ugh
    dsagman • 08/16/2022 at 21:01 • 0 comments
    So I still can't get the looper working. I tried a workaround where I would start a subprocess to run SOX aplay to play the looping audio. But.....it conflicted with the already running pyo server and could not get access to the audio output at the same time. So, I am now seeing if using pulseaudio or jack server might fix the SIGSEGV I get from pyo's SfPlayer.
    Why? Because I had SfPlayer working on my Arch Linux laptop and not running on the Raspberry Pi and one difference is the laptop uses Jack. I've been trying to avoid this, because it adds another layer into the audio stack and everything feels a bit fragile already.
    So I am recompiling pyo with Jack support.
    In the meantime, I broke everything when I installed pulseaudio. I almost lost my mind. But I found the problem, it was ALSA had been reset to use the mic input, and not line input. Who knows why?
    So here's a picture of how the ALSA setup should look when you run alsamixer. (Also added this to the google slides doc.)
  • MCP3008 Wiring
    dsagman • 08/16/2022 at 20:54 • 0 comments
    Added a photo of the MCP3008 board that Ben built. Much nicer than mine. Good reference.
  • Not so easy
    dsagman • 08/12/2022 at 15:58 • 1 comment
    OK, I've got a button working, and recording working, but when I try to do playback I get:  terminated by signal SIGSEGV (Address boundary error)
    I think the problem may be that I am somehow starting the pedalmaster main program at the same time and they are conflicting. So maybe not my code.
    Here's the code, and I have button wired up to GPIO pin 2.
    # Looper. This is test code that:
    # on GPIO connected button press: starts a recording
    # second press: stops listening and plays a loop of the recording
    # third press: stops looping and returns to initial state
    #!/usr/bin/env python3
    from gpiozero import Button
    from signal import pause
    import pyo
    import os
    s = pyo.Server().boot()
    s.start()
    audio = pyo.Input()
    loop_file = os.path.dirname(os.path.abspath(__file__))+'/myloop.wav'
    times_clicked = 0
    def looper_func(key):
        global times_clicked, rec, looper, audio, loop_file
        if times_clicked == 0:
            print("Recording")
            rec = pyo.Record(audio, filename=loop_file, fileformat=0, sampletype=1).out()
        if times_clicked == 1:
            print("Looping")
            rec.stop()
            looper = pyo.SfPlayer(loop_file, loop=True).out()
        if times_clicked == 2:
            print("Waiting")
            looper.stop()
        times_clicked = (times_clicked+1)%3
        print(times_clicked)
    switch = Button(2)
    switch.when_pressed = looper_func
    pause()
View all 17 project logs
View all 3 instructions
actionjackson wrote 07/22/2022 at 22:36 • point
Does / can your project run guitar amp sims, cabinet impulses, through the class D power amp?
Great project by the way.
dsagman wrote 08/11/2022 at 22:20 • point
I don't have the skills to code up amp sims, but the amp is basically directly connected to the pi, so anything that will run on the pi can be output to through the amp and use the input of the guitar.
dsagman wrote 07/21/2022 at 20:47 • point
Super cool!
Ben mcmunn wrote 07/08/2022 at 18:43 • point
Guitar teacher here! This thing took on a life of its own...Mine is in the works!
