I updated the code on github and the instructions on the looper. I have to make a pedal next. I expect the router will see some use as I want this as janky as possible and I will likely just hock out a chunk of 2x4 to house the switch and connector.
A project log for Raspberry Pi Guitar Amplifier
Guitar Amplifier and effects made with Raspberry Pi and reused Vox amplifier case
