I just finished the multi fridge compressor unit and did some testing with it.
(I built a unit made of 8 fridge compressors that I converted to air compressors)
The airflow is pretty high and I think it will do its job pretty well. I will add another build log with pictures of it soon.
I also did more testing of underwater plasma cutting, but I think for the sake of cutting quality and prevention of rusty linear rails I will ditch that idea and do the cutting in the common way.
Maybe I add a water pump for protection or part cooling, but no more underwater cutting for now (until I change my mind again 😅)
Now I will focus my work on doing test cuts and finding ways to optimize the system.
So, I think solving the problem of a loud air compressor is a major step toward making plasma cutting as apartment friendly as 3D printing.
I cut a hole in the top of the cover to prevent water condensation and rust on the bearings. I also lowered the water level to a minimum to extinguish the sparks that falls to the bottom.
Could you make video of that compressor shelf? I'm curious how loud it sounds. How much power does it take for how much air?
Yes, I will post a video and more pictures of it soon, but first I have to
clean up the mess I left behind during construction.
