TapeDump64 is a simple and inexpensive adapter that can interface a Commodore Datasette to your PC via USB in order to dump your old software saved on tapes as TAP files. It is inspired by TrueTape64, a similar project by Francesco Vannini. The integrated USB to serial converter can also be used as a SerialUPDI programmer for the on-board ATtiny202/212/402/412 microcontroller, so that no additional hardware is required to flash the firmware. For an advanced version that can also write on tapes, take a look at TapeBuddy64.
