Electronics is based on Microchip PIC 24FJ256GB10. microcontroler. This 16 bits MCU has a native USB port which allows easy interface with a PC.
It has also 9 hardware PWM ports which are perfect to drive motors.
Together with the PIC we find :
- A triple H bridge driver L6234 used to pilot the motor
- a Reflective photosensor (photoreflector) RPR220
- a real time clock calendar DS1337C used to keep time when the power is off
- an audio amplifier MAX9716 for the clock to speak (to be done)
- a 3,3V voltage regulator
- a few SMD components to "make the glue"
The schematics are quite simple :
![](https://cdn.hackaday.io/images/2635561657285104659.jpg)
Note that you can safely forget the audio amplifier part which was only added there "for fun" (see the devoted log to be published)
![](https://cdn.hackaday.io/images/9551991657285516533.jpg)
The motor is driven by the H bidge driver L6234
![](https://cdn.hackaday.io/images/8141551657286165930.jpg)
Its outputs are connected directly to the motor connector scavaged from the original board.
Note that VS pin is said to be 12V, but I do power this system only with the 5V DC coming from the USB plug.
It works, the motor is not rotating very fast but it is enough for a clock and the H bridge does not heat at all !
Furthermore, you do not need to add any external power supply, only a smartphone charger !
The heads coil is driven directly via a PWM pin issued from the PIC. The Mosfet is there to cope with the 3.3V limitation of the PIC's IO...
![](https://cdn.hackaday.io/images/1109771657286552542.jpg)
Finally the photo transistor is powered at 5V and is connected to a 5V tolerant input pin of the PIC :
![](https://cdn.hackaday.io/images/2288331657286912709.jpg)
That's all for the schematics which is finally quite simple.
You can find all the eagle files including PCB here.
