As promized, I am just starting to port my HDD clock on a new MCU : ESP32
This would have several adavantages:
- wifi and bluetooth are enabled. No need to connect to a PC via USB
- ESP32 lolin lite breadboard has everything needed: power supply, battery, USB to serial programmer
- no need for the RTC chip as wifi connection is available to get time over NTP
- easy to hook up an android App to this MCU
Here are the simplified schematics
It's indeed much simpler than the PIC circuitery !
- one mosfet is still needed to drive the coil
- one L6234 to drive the BLDC motor.
- one RPR220 as a position sensor.
JP Gleyzes
