TThe file (module) neotrellis_animations.py encasulates the neopixels in the 4x4 key pad matrix. Note these are NOT the conventional NeoPixel class. They are accessed through the Adafruite_seesaw.neopixel version. At time of project (and this writeup), the release version of adafruit_seesaw package (library) has its own independent NeoPixel class. Of particular annoyance is this class does not derive from Adafruit_CircuitPython_PixelBuf class, which means it cannot be used as a direct replacement for Adafruit_CircuitPython_NeoPixel, especially in the rather nice Adafruit_led_animations package. As mentioned in main project details, Neradoc has a pull request for their version of seesaw that does derive its NeoPixel class from PixelBuf. The github's lib folder contains a snapshot of that fork of the seesaw package.
The module starts off with the imports and a few module global variables. We pull in all 13 of the current animations.
from adafruit_led_animation.animation.blink import Blink
from adafruit_led_animation.animation.sparklepulse import SparklePulse
from adafruit_led_animation.animation.comet import Comet
from adafruit_led_animation.animation.chase import Chase
from adafruit_led_animation.animation.pulse import Pulse
from adafruit_led_animation.animation.sparkle import Sparkle
from adafruit_led_animation.animation.rainbowchase import RainbowChase
from adafruit_led_animation.animation.rainbowsparkle import RainbowSparkle
from adafruit_led_animation.animation.rainbowcomet import RainbowComet
from adafruit_led_animation.animation.solid import Solid
from adafruit_led_animation.animation.colorcycle import ColorCycle
from adafruit_led_animation.animation.rainbow import Rainbow
from adafruit_led_animation.animation.customcolorchase import CustomColorChase
from adafruit_led_animation.sequence import AnimationSequence
from adafruit_led_animation import helper
import adafruit_led_animation.color as Color
from onboard_neopixel import blinkOnBoardPixel
# a local reference to the neotrellis.pixels PixelBuf derived NeoPixel
__trellis_pixels = None
__allBlack = None
__trellis_pixel_columns = None
__trellis_pixel_rows = None
Next up we define a list, rainbowPalette, that has 16 somewhat contrasting colors. These will later be available to map to default key colors. Selecting these colors could be a whole huge discussion.
# we have Color.BLACK as well as the other color names (and colorwheel() ) from led_animations
# we need a 16 color palette that does NOT contain black - one for each button in keypad
rainbowPalette = [
0xa0002, 0x80004, 0x50007, 0x30009,
0xb, 0x10b, 0x308, 0x606,
0x804, 0xb01, 0xb00, 0x30900,
0x50700, 0x70400, 0xa0200, 0xc0000
def print_rainbowPalette():
print("Rainbow Palette:", rainbowPalette)
print("Rainbow Palette: ", end=" ")
for clr in rainbowPalette:
print(hex(clr), end=", ")
print()
def show_rainbowPalette():
global __trellis_pixels
print("RainbowPalete blinking on board pixel")
print("clr ", hex(clr))
BLINK_COLOR = clr
__trellis_pixels.fill(clr)
blinkOnBoardPixel()
Then we define a couple more public module variables. current_animation references the currently active animation. trellisAnimations[] is a list of all the locally created animations. The first 16 entries will be used over in our neotrellis_keypad module. They are associated by index order with the 16 keys.
# define some module variables
current_animation = None
trellisAnimations = []
the setup_animations(neotrellis):method comes next. It takes a neotrellis object parameter and defines a number of animations. The code is almost directly from the Adafruit_led_animations.examples.led_animation_all_animations demonstration program.
setup_animations() is the main entry. It takes a NeoTrellis as a parameter and fills in the globals. The animations are created as local named objects in setup_animations(), with references hidden away in trellisAnimations[]. We do keep a module reference to the Solid Black animation in __allBlack. There is likely a better organization of references, but that will really depend on how the code gets reused for a real neotreillis product.
# this init function creates a bunch of animations in the trellisAnimations[]
def setup_animations(neotrellis):
global __allBlack
global __trellis_pixel_columns
global __trellis_pixel_rows
__trellis_pixels = neotrellis.pixels
__trellis_pixels.fill(Color.WHITE)
#trellis.pixels.fill(Color.BLACK)
blink = Blink(__trellis_pixels, speed=0.5, color=Color.JADE)
color_cycle = ColorCycle(__trellis_pixels, speed=0.4, colors=[Color.MAGENTA, Color.ORANGE])
comet = Comet(__trellis_pixels, speed=0.1, color=Color.PURPLE, tail_length=4, bounce=True)
chase = Chase(__trellis_pixels, speed=0.1, size=3, spacing=6, color=Color.WHITE)
pulse = Pulse(__trellis_pixels, speed=0.1, period=3, color=Color.AMBER)
sparkle = Sparkle(__trellis_pixels, speed=0.1, color=Color.PURPLE, num_sparkles=6)
solid = Solid(__trellis_pixels, color=Color.JADE)
rainbow = Rainbow(__trellis_pixels, speed=0.1, period=2)
sparkle_pulse = SparklePulse(__trellis_pixels, speed=0.1, period=3, color=Color.JADE)
rainbow_comet = RainbowComet(__trellis_pixels, speed=0.1, tail_length=16, bounce=True)
rainbow_chase = RainbowChase(__trellis_pixels, speed=0.1, size=3, spacing=2, step=8)
rainbow_sparkle = RainbowSparkle(__trellis_pixels, speed=0.1, num_sparkles=4)
custom_color_chase = CustomColorChase(
__trellis_pixels, speed=0.1, size=2, spacing=3,
colors=[Color.ORANGE, Color.WHITE, Color.JADE]
# thats only 13 built in! need 16 to have one each key
allWhite = Solid(__trellis_pixels, color=Color.WHITE)
allBlack = Solid(__trellis_pixels, color=Color.BLACK)
__allBlack = allBlack
allGray = Solid(__trellis_pixels, color=(8,8,2))
allOrange = Solid(__trellis_pixels, color=Color.ORANGE)
allRed= Solid(__trellis_pixels, color=Color.RED)
allBlue = Solid(__trellis_pixels, color=Color.BLUE)
allGold = Solid(__trellis_pixels, color=Color.GOLD)
Halfway thru setup_animations() we come to the rather nice PixelMaps. From the adafruit learn on led_animations: " The PixelMap helper enables you to treat a strip or strips of LEDs as a grid for animation purposes. It also works great with LED matrices that are actually a strip of LEDs arranged in a matrix, such as the NeoPixel FeatherWing." [and the NeoTrellis]
We create two PixelMaps, one to reference Columns (vertical) keys and one to reference Rows (horizontal) keys. These are then used to create animations that run across/up/down the keypad.
At the end of setup_animiations(), the trellisAnimations[] list is filled and we set the current_animation to be Solid Gray.
# create some pixelMaps for rows and columns
__trellis_pixel_columns = helper.PixelMap.vertical_lines(
__trellis_pixels, 4, 4, helper.horizontal_strip_gridmap(4, alternating=False)
__trellis_pixel_rows = helper.PixelMap.horizontal_lines(
# and build some animations using PixelMaps (from example, mod for size)
comet_h = Comet(__trellis_pixel_rows, speed=0.1, color=Color.PURPLE, tail_length=3, bounce=True)
comet_v = Comet(__trellis_pixel_columns, speed=0.1, color=Color.AMBER, tail_length=6, bounce=True)
chase_h = Chase(__trellis_pixel_rows, speed=0.1, size=3, spacing=6, color=Color.JADE)
rainbow_v = Rainbow(__trellis_pixel_columns, speed=0.1, period=2)
rainbow_chase_v = RainbowChase(__trellis_pixel_columns, speed=0.1, size=3, spacing=2, step=8)
rainbow_chase_h = RainbowChase(__trellis_pixel_rows, speed=0.1, size=3, spacing=3)
rainbow_comet_v = RainbowComet(__trellis_pixel_columns, speed=0.1, tail_length=7, bounce=True)
# build an array of all those animation, first 16 will be tied to keypad actions later
global trellisAnimations
# first 16 will match to key pad index 0-15
blink, color_cycle, comet, chase,
pulse, sparkle, comet_h, rainbow,
sparkle_pulse, rainbow_comet, rainbow_chase, rainbow_sparkle,
custom_color_chase, rainbow_chase_v, rainbow_chase_h, rainbow_comet_v,
# any more are just filler here
allWhite, allBlack, allRed, allBlue, allGold, allOrange, allGray,
chase_h, comet_v, rainbow_v,
# start with simple solid Gray animation
global current_animation
current_animation = allGray
print ("animations setup current_animation: ", current_animation)
Lastly the module defines some functions to act on the current_animation.
def set_all_black_animation():
global __allBlack
current_animation = __allBlack
def set_animation_byIndex(idx):
if idx in range(len(trellisAnimations)):
current_animation = trellisAnimations[idx]
def freeze():
current_animation.freeze()
def resume():
print ("resume current_animation: ", current_animation)
current_animation.resume()
Jerry Isdale
