Signal levels at any stage
A project log for 32MHz spectrum + SDR + FT8 in an FPGA
A 0 - 32MHz FPGA based Software Defined Radio (AM SSB FT8) by ready modules->cheap and easy Last add: Aug 14th SW update to include GFSK
guidoGuido 12/29/2022 at 18:030 Comments
To keep the "right" digital level at every stage of the SDR looks quite challenging to me.
"Right" means:
To test and simulate such a level in any stage (complex multiplier, CIC, FIR etc.)  I designed the test generator so that it outputs the maximum peak to peak signal level, which at 12 bits is between -2048 and 2047. This is the same maximum signal level the ADC can handle before saturating.
Then I designed every following stage to output the maximum output level given the maximum input level. For example, see the complex multiplier.
