Built the very first assembly for a few experiments
A project log for 32MHz spectrum + SDR + FT8 in an FPGA
A 0 - 32MHz FPGA based Software Defined Radio (AM SSB FT8) by ready modules->cheap and easy Last add: Aug 14th SW update to include GFSK
guidoGuido 08/29/2022 at 06:200 Comments
As you can see in the section "first assembly", I boxed the AD9226 ADC and connected it to the EBAZ4205. Using Xilinx Vivado now I would like to test the single components: 65MHz clock generator output, Analog to Digital capabilites, Digital Down Conversion and so on.
