The ADC board analog input
A project log for 32MHz spectrum + SDR + FT8 in an FPGA
A 0 - 32MHz FPGA based Software Defined Radio (AM SSB FT8) by ready modules->cheap and easy Last add: Aug 14th SW update to include GFSK
guidoGuido 11/09/2022 at 19:510 Comments
The second lesson I learned was about the unbalanced -> balanced amplifier AD8138 feeding the balanced AD9226 input. Its analog input schematic for the board I used is something like this:
AD9226 12-BIT 65 SMPS  BOARD - original schematic
Therefore the overall amplification between VINA-VINB and INPUT_50_Ohm is approximatively:
200//62
-------------------- x (200/200 + 1) = 0,38 i.e. -8,4 dB
200 + 200//62
Well, connecting my End Fed Long Wire Antenna to the Input_50_Ohm I realised that the AD9226 samples (12 bits) were around 0x820 and 0x07E. So I decided to amplify a bit :)
