Ready to receive HF Radio Stations
A project log for 32MHz spectrum + SDR + FT8 in an FPGA
A 0 - 32MHz FPGA based Software Defined Radio (AM SSB FT8) by ready modules->cheap and easy Last add: Aug 14th SW update to include GFSK
guidoGuido 12/29/2022 at 20:370 Comments
Now almost everything is ready to receive HF Radio Stations.
(*) designed and simulated but not tested yet
After a few attempts, using a simple C++ program running on Linux in the Zynq Programmable System I set:
and obtained a clear 1KHz tone at the output of the PCM5102 I2S ADC (around 1,5 Vpp),
Then I successfully tried a few Radio Stations after verifying they were receivable at that time using http://kiwisdr.com/public/
