Hackaday.io Hackaday.io
Sign up Log in
Climate Resilient Communiti - Power Cube
An attempt at the Climate Resilient Community challenge, featuring a self-powered Pi or ESP in a compact cube design.
tanguyTanguy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.3k views
0 comments
1.8k followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 1
    • View all
  • Logs 15
    • View all
  • Instructions 0
  • Discussion 0
  • Supplyframe DesignLab: 2022 Hackaday Prize
View Gallery
1.3k
0
1.8k
16
Team (1)
  • tanguyTanguy
Join this project's team
MISC
ongoing project
solar cube cubesat energie self-powered Climate Resilient Communiti computer raspberry pi 2022hackadayprize
Related lists
Just Cubes
It rolls down stairs alone or in pairs, it's cube!
This project is submitted for
  • Climate Resilient Communities
This project was created on 07/18/2022 and last updated 2 years ago.
Starting from
Buy on Tindie
has orders / reviews
Ships from
Description
This is my attempt at the Climate Resilient Community challenge, using a self-powered Pi or ESP in a cube.
The goal is to create a cheap self-powered small computer (like a Raspberry Pi), or if power isn’t sufficient, an ESP.
I took inspiration from the design of CubeSats, the micro-satellites.
Files
FullCube.STEP
step - 682.58 kB - 07/03/2024 at 09:54
Download
SingleFace.STEP
step - 409.82 kB - 07/03/2024 at 09:54
Download
link.STL
Link part to assemble the 6 faces into a cube shape
Standard Tesselated Geometry - 1.73 MB - 07/03/2024 at 09:27
Download
Components
  • 24 × 6v 0.5w Solar panels (x4 by faces) https://fr.rs-online.com/web/p/panneaux-solaires/1793740?searchId=4c3790b5-ace9-4025-be7c-09f6796eb4db&gb=s
Project Logs
Collapse
  • All sides
    Tanguy • 08/16/2022 at 17:34 • 2 comments
  • Make a cube
    Tanguy • 08/12/2022 at 12:58 • 0 comments
  • Glue and solder
    Tanguy • 08/10/2022 at 11:31 • 0 comments
  • PCBs are here !
    Tanguy • 08/08/2022 at 14:05 • 0 comments
  • Receive more of this
    Tanguy • 08/02/2022 at 15:29 • 0 comments
  • Test PCB pannel
    Tanguy • 08/01/2022 at 07:41 • 0 comments
  • Ok.. i'm gonna give up on the resin
    Tanguy • 07/29/2022 at 10:51 • 0 comments
  • Wish me luck
    Tanguy • 07/23/2022 at 13:43 • 0 comments
  • WIP & tests
    Tanguy • 07/22/2022 at 11:22 • 0 comments
    I made two, to try resin on one
    4x6v = 24v
  • Let's try something else (6v 0.5w mini panel)
    Tanguy • 07/21/2022 at 10:35 • 0 comments
View all 15 project logs
Log In/Sign up to comment
Sign up with Github
OR
open source raspberry pi handheld retro gaming console
Project Owner Contributor
Pi Tin
jackw01jackw01
New generation Raspberri Pi PICO based universal retrocomputer and communicator, specially designed for Circuitpython / Micropython program
Armachat & PICOmputer fusion with Raspberry PICO
bobriciusbobricius
A 3d printed enclosure to house multiple Pis, updated for the Raspberry Pi 4
Raspberry Pi Rack for the Pi 4
dave-peduDave Pedu
A Raspberry pi based simple, functional, and multi-tasking cyberdeck optimized for outdoor adventures.
HAMDECK CYBERDECK
kaushlesh-c-kd9vfuKaushlesh C. ( KD9VFU )
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Climate Resilient Communiti - Power Cube", please tell us the reason.
Send message
Remove Member
