The PCB has a center hole and some cutouts for the components.
![](https://cdn.hackaday.io/images/6091821658242774800.jpg)
The LEDs are placed first using a resin printed jig. Matching holes are holding the LEDs in place while soldering one side to the PCB.
![](https://cdn.hackaday.io/images/8273801658242849013.jpg)
When all LEDs are soldered to the top
![](https://cdn.hackaday.io/images/4527761658242938917.jpg)
the PCB is removed from the jig and the bottom side is soldered.
![](https://cdn.hackaday.io/images/1789241658243027454.jpg)
The ATtiny 45 is solder in a notch of the PCB in 90° orientation by using two resistor nets (10 Ohm), one per side.
![](https://cdn.hackaday.io/images/9457391658243138556.jpg)
The booster converter with the inductor are also solder 90° with corresponding pads on top and bottom layer. If the battery voltage drops below 3.6V, the blue LEDs of the WS2812B stop working, therefor the booster is used to ensure a proper voltage level.
![](https://cdn.hackaday.io/images/2347821658243409162.jpg)
