The fiber optics was harder to install than I thought it would be but I got it on the first try which is always nice.
I cut it at 5 inch increments and I needed 8 per hole with a total of 8 holes. Bringing to a total of 64 pieces.
Install : Insert all 8 pieces and leave about a half inch sticking out, drop off super glue near hole and cut flush then sand smooth.
So much super glue , sanding is the only reason it looks nice.
I'm currently trying to figure out the diameter of the fiber optic bundle so I can start designing the adapter to the light source.
