Now that the Excel Paper Model and the KIM Uno version are working and producing the same results, here is a third implementation to make experimenting with this machine more accessible to everybody,
https://github.com/arduinoenigma/Mystery6502Machine/blob/master/EnigmaZ30.ino
This program is not part of the #1kBChallenge.
To use it, open a Serial Monitor.
Send ! and and any combination of 1,2,3 to set the wheel type and their position.
Send @ and four numbers to set the ring settings
Send # and four numbers to set the visible wheel position.
The set commands can be concatenated to set the whole key at once.
After !,@ or # receive the required digits, the current key will be shown.
Send a number and it will be encrypted with the current machine settings.
For example:
1111 encrypts it with the current machine settings
!312 sets the wheels to 3,1,2
@1111 sets the ring settings to 1111
#6789 sets the wheel positions to 6789
!312@1111#6789 sets the whole key.
1111 encrypts it with the key set on the step before.
$ prints the current key, will print 03+01+02+01+01+01+01+06+07+08+09 the sequence to enter in the KIM Uno at address 0050 to configure the machine
