Hackaday.io Hackaday.io
Sign up Log in
Make Fake Fireflies/Lightning Bugs for your Garden
Fireflies, or lightning bugs, one of natures miracles, In this tutorial I'll show you how to make your own!
rob-smithRob Smith
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 7
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
318
0
0
0
Team (1)
  • rob-smithRob Smith
Join this project's team
  • Source Code
  • 3DPrinted Box
  • Youtube Video
  • Patreon
completed project
hardware
arduino solar Fireflies firefly lightning bug
This project was created on 07/21/2022 and last updated 4 years ago.
Description
Fireflies, or lightning bugs, one of natures miracles, but not so common in the UK, especially in my garden. In this tutorial I'll show you how to make realistic solar powered fireflies (lightning bugs) for the garden.
The secret to this project is to use individually addressable LEDs, on a copper wire string, combined with a solar cell, charge/boost converter and an Arduino.
Other charge controllers may make this easier as some will cut the power while charging, but we're going to put the Arduino into low power mode anyway.
I'm using the Arduino Pro Mini from Sparkfun, as its really easy to make it use less power (and I have it already), other smaller micros could also be a good alternative.
Details
Files
Schematic with MOSFET added
Portable Network Graphics (PNG) - 2.62 MB - 08/01/2022 at 08:24
Preview
Components
  • 1 × arduino pro mini (sparkfun)
  • 2 × 10K Resistor
  • 1 × 1M Variable Resistor
  • 1 × 2W 6V Solar Panel
  • 1 × TP4056 Charge/Boost Converter
View all 7 components
Log In/Sign up to comment
Sign up with Github
OR
This solar powering unit is a time switching battery powered solar charged circuit, used to power an Arduino Uno and some peripherals.
Project Owner Contributor
Solar powering unit for Arduino
patel-darshilPatel Darshil
The 2016 Hackaday Prize
NodeLP is designed for low power sensor node.Use it with any board such as Arduino, ESP8266, CC3200, CC2541 and other WiFi, BLE dev boards.
NodeLP - Low power solution for DIY Sensor
michael-wenMichael Wen
Use Konekt's M2M Platform to Connect an Arduino to Cellular!
Connecting Arduino to Cellular via Konekt
pat-hoganPat Hogan
Some time we need to make Arduino board working on outdoor, in this case we need a mobile power source for the Arduino, this is the best way
9V Rechargeable batteries box for Arduino
yakeyake
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Make Fake Fireflies/Lightning Bugs for your Garden", please tell us the reason.
Send message
Remove Member
