Using the Silicon Labs toolstick and a C8051F850 daughter board I have configured the following setup:
- 2 x PWM outputs running in phase at 95.7KHz using an 8-bit counter
- 1 x 10-bit ADC input
- 1 x UART running at 115200 baud
The internal clock is running at 24.5MHz.
Currently an ISR is used to update the PWM duty cycle but the next steps will be to...
- Refine the PID controller
- Include a timer to execute the PID routine from an ISR
I'm also prototyping hardware to begin testing the setup as a boost converter.
Ashley Robinson
