Dev board peripheral experiments
A project log for Switcher
A switch mode power supply controlled by an 8051 processor.
ashley-robinsonAshley Robinson • 12/03/2016 at 16:27•0 Comments
Using the Silicon Labs toolstick and a C8051F850 daughter board I have configured the following setup:
The internal clock is running at 24.5MHz.
Currently an ISR is used to update the PWM duty cycle but the next steps will be to...
I'm also prototyping hardware to begin testing the setup as a boost converter.
