Hackaday.io Hackaday.io
Sign up Log in
Hack it Back - Rise of the Hoverboard
This is my attempt to the Hack it Back challenge, with my hoverboard based rover robot
tanguyTanguy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.7k views
2 comments
14 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 9
    • View all
  • Instructions 0
  • Discussion 2
  • Supplyframe DesignLab: 2022 Hackaday Prize
View Gallery
2.7k
2
14
14
Team (1)
  • tanguyTanguy
Join this project's team
MISC
ongoing project
HoverBoard Hack it Back ROBOT rover 2022hackadayprize
This project is submitted for
  • Hack it Back
This project was created on 07/24/2022 and last updated 4 年前.
Description
[EDIT] As the challenge is over, i will continue posting updates and logs on the original project page: https://hackaday.io/project/185426-not-so-small-rover
This is my attempt to the Hack it Back challenge, with my hoverboard based rover robot.
Hoverboard are here and accessible for years, with powerful motors, battery, controllers.
All the parts that are needed to build a real robot.
I decided to do that, and have fun with a custom and original robot design.
It's a big baby of 25kg, with a full aluminum frame, a spring suspension system and 4 motors wheels.
The remote controller is here: https://hackaday.io/project/185425-universal-robot-remote
My goal is to make a real autonomous rover, it could be a cheap solution for any kind of exploration, transportation, inspection.
Components
  • 2 × Old Hoverboard (for the wheels & batteries) (you can find broken one for around 20 buck on ebay)
  • 4 × 400x20x40 aluminium extrusion https://www.systeal.com/fr/profiles-aluminium-6-mm/1226-profile-aluminium-v-slot-20x40-fente-6-mm.html
  • 16 × Tensioner cord https://www.amazon.fr/gp/product/B09MRVFS7T/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  • 8 × 6206-2RS 30 x 62 x 16 mm bearing https://www.amazon.fr/gp/product/B07LD1D94T/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  • 100 × M6x70mm screw https://www.amazon.fr/gp/product/B0953HFFKT/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Project Logs
Collapse
  • Electronic box for rpi & dropix
    Tanguy • 08/10/2022 at 11:28 • 0 comments
  • Hide and protect the wires
    Tanguy • 08/08/2022 at 13:58 • 0 comments
  • Wiring in progress
    Tanguy • 08/07/2022 at 18:13 • 0 comments
  • Big red button for safety, and 2 axis cheap camera for fun
    Tanguy • 07/24/2022 at 12:41 • 0 comments
  • Some damping tests
    Tanguy • 07/24/2022 at 12:38 • 0 comments
  • Here come the new frame for ours old Hoverboard component
    Tanguy • 07/24/2022 at 12:36 • 0 comments
  • It's time to design something cool
    Tanguy • 07/24/2022 at 12:23 • 0 comments
  • Let's take Hoverboard apart !
    Tanguy • 07/24/2022 at 12:21 • 0 comments
  • ​Buy 4 broken Hoverboard for 100 bucks
    Tanguy • 07/24/2022 at 12:20 • 3 comments
View all 9 project logs
Log In/Sign up to comment
Sign up with Github
OR
Joc wrote 08/03/2022 at 22:26 • point
This is honestly fantastic. Do you have any more info on your materials such as cost and where the metal was fabricated?  Will you make this opensourced?  This is one of the best projects I've seen!  Would love to see more in-depth of installation guide and such! Keep up the awesome work !
Tanguy wrote 08/07/2022 at 18:27 • point
Thanks a lot ! I have updated the parts list, but it's not final for the moment.
The aluminum part come from https://www.john-steel.com
they cut what you want from dxf files.
At the moment I don't know if I will make it opensource, if it works well, I would like to find a way to sell kits or something. But before that, there is still a long way to go !
a Robot dog build with fully custom BLDC actuators
Project Owner Contributor
Robot Dog
alexisAlexis
ROS based 2WD, 4WD, Mecum Drive, and Ackermann Steering robots.
Linorobot - 3 New ROS compatible platforms
juan-miguel-jimenoJuan Miguel Jimeno
A robot that utilizes compression springs and BLDCs to navigate various pipe structures.
Pi Fly 7
jfriesjfries
A reaction wheel inverted pendulum driven with simpleFOC and made from 3d prints with embedded metal rings.
A Simple Balancing Robot
alexchunlinalexchunlin
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Hack it Back - Rise of the Hoverboard", please tell us the reason.
Send message
Remove Member
