Tremor Nail Clipper (TNC)
The TNC is an assistive technology to enable humans struggling with hand tremors to clip their nails independently.
Public Chat
The Tremor Nail Clipper (TNC) is an innovative assistive technology (AT) to enable humans struggling with hand tremors to clip their nails independently, thus helping with the day to day life. It clamps onto most tables (thickness under 5cm), and using Velcro straps stabilizes your finger in place to be able to just clip fingernails easily.
You will need a hex bolt size M8x70mm (with a size 13 hex) with a corresponding square nut and nylon jam nut. Also some kind of foam to cushion the finger and a Velcro strap or an elastic band.
The print was done using a Prusa i3 Mrk3, with 40% infill, 4 perimeters and using the gyroid fill pattern
P.S. I included the SolidWorks files incase you want to change something to fit your needs more.
Tremmor NC.STL
Standard Tesselated Geometry - 482.60 kB - 07/25/2022 at 13:52
Download
Tremmor NC.SLDPRT
sldprt - 690.12 kB - 07/25/2022 at 13:52
Download
thumbscrew.SLDPRT
sldprt - 633.25 kB - 07/25/2022 at 13:52
Download
thumbscrew.STL
Standard Tesselated Geometry - 1.01 MB - 07/25/2022 at 13:52
Download
table part.SLDPRT
sldprt - 273.47 kB - 07/25/2022 at 13:52
Download
View all 8 files
alan_r_cam wrote 08/01/2022 at 03:54 point
Nails that need trimming are also on - your feet.
Toenails can be out of reach due to hip surgery, or simple lack of flexibility as a result of age or illness. Will there be a foot version of this ?
Toe length and shape will probably preclude the Velcro straps.
