The third version of the prototype case has been printed:
- Holes for stemma connectors no longer exposed on the bottom half (still visible up top due to lack of space
- Reduced exposed space around the UV sensor
- Reduced exposed space around the OLED
- Adjusted (but not entirely fixed) screw holes
Probably enough 3D printing for now, next up - I'll try to get it battery powered and maybe some code improvements.
