In the figure below I show the lid of the box to make the marks for the drill holes.
![](https://cdn.hackaday.io/images/6233441658976098066.jpg)
Now below we see how this piece was after drilling.
![](https://cdn.hackaday.io/images/9908321658976077167.jpg)
Once the holes are large enough, then it's time to attach the connectors.
![](https://cdn.hackaday.io/images/2887611658976053787.jpg)
In the figure below I show you the pieces that I print on the 3D printer. These pieces are used to fix the Arduino MKR WAN 1300 board and the LCD display.
![](https://cdn.hackaday.io/images/6135961658976024717.jpg)
In the image below you can see how to assemble the 16x2 LCD display that comes in the kit.
![](https://cdn.hackaday.io/images/4833741658975997475.jpg)
Then we fix the Arduino MKR WAN 1300 board, the 16x2 LCD display, the DS18B20 sensor and the antenna.
![](https://cdn.hackaday.io/images/7739171658975926826.jpg)
The transmitter would look like the figure below.
![](https://cdn.hackaday.io/images/141031658975899863.jpg)
As a power supply I used a generic 5V Portable Charger Power Bank 16800 mAh. In addition to providing more accurate voltages, this device gave me better results since it has a power button, a voltage regulator and detects when a device is connected or not.
![](https://cdn.hackaday.io/images/6000421658975878578.jpg)
I also recommend using a heavy-duty USB to make a good connection
![](https://cdn.hackaday.io/images/3236521658975852968.jpg)
SCHEMATIC DIAGRAM
After adding the 16x2 display, the wiring diagram of the receiver is as shown below.
![](https://cdn.hackaday.io/images/6298121658975799567.png)
CODE
All the information needed to install the library you can get in this link: Grove-LCD RGB Backlight Library from Github
After making these changes, the transmitter code is shown below:
LoRaSender_v2.ino
// AUTHOR: GUILLERMO PEREZ GUILLEN
#include <SPI.h>
#include <LoRa.h>
#include <OneWire.h> // DS1B20->
#include <DallasTemperature.h>
#include <Wire.h> // LCD->
#include "rgb_lcd.h"
rgb_lcd lcd;
const int colorR = 173;
const int colorG = 255;
const int colorB = 47;
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
int counter = 0;
void setup() {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.setRGB(colorR, colorG, colorB);
// Print a message to the LCD.
lcd.print("ECOLOGY!");
lcd.setCursor(0, 1); // LCD
lcd.print("LoRa Sender");
if (!LoRa.begin(915E6)) {
lcd.print("Starting LoRa failed!");
while (1);
sensors.begin();
void loop() {
sensors.requestTemperatures(); //The command to read the temperature is sent
int temp= sensors.getTempCByIndex(0); //The temperature is obtained in ยบC
lcd.clear();
lcd.setCursor(0, 0); // LCD
lcd.print("Packet:");
lcd.setCursor(8, 0); // LCD
lcd.print(counter);
lcd.print("Temp:");
lcd.setCursor(8, 1); // LCD
lcd.print(temp);
// send packet
LoRa.beginPacket();
LoRa.print(temp);
LoRa.endPacket();
counter++;
delay(4000);
