This 4x4 keypad is designed transform the Fri3d Camp 2022 Badge in a configurable bluetooth keypad. They PCB design has some nifty features built-in. The left most corner contains a diode bending corner, making sure that your diodes have their leads bent in the right spot will help during assembly. The other useful feature if a built in lube station. The X cutout will snugly fit a stem whilst the rectangular hole will fit the body the switch you're cleaning.
Wim Van Gool
Jayken
Arnov Sharma
Nicolas Schurando
nicoud jean-daniel
