Servo arm
A project log for PostCycla
DIY smart bike trainer with "virtal ride" capability
richard-deiningerRichard Deininger • 12/02/2016 at 07:51•0 Comments
So lets do some hardware stuff.
To change the resistance on the bike trainer I had to "update" the bowden cable parts.
I didn't want to destroy the old system so I manufatured my bowden cable, from some bike break cables and a nail. It's a bit more rigit due to the thickness, but this will help during "push and pull" of the servo.
Manifacturing my own bowden cable
This new cable was then fixed on the eddy current brake (this part previously had a spring, but the servo can push and pull the cable,... so no need for it).
Here my first test fit.
The insides
And the first test fit with everything put back together.
For testing I used an remote control and found that the servo needed more power.
Dry test with RC
Next thing to do was to build a servo fixture.
So I bent and tack welded some angle steel I had around the shop.
(I know,... I need more practice welding)
servo fixture
Finally some holes and threading for the servo and the new servo arm with the correct length.
Fitting the servo
Last check back with the plans.
Plans and IRL
And one last (blurry) picture with everything put back together.
Everything put together
