How It Works
Brief Summary
I started with a well-known disassembly of Combat (by Harry Dodgson, later improved by Nick Bensema and Roger Williams). To this, I added a K-nearest neighbor algorithm that uses examples from a training dataset to make a prediction about the best course of action for the AI-controlled tank to take.
Details
There were a number of problems to overcome to fit an AI algorithm into an already tightly-packed 2 KB ROM on the highly resource-constrained Atari 2600. First, a bit about the platform — the Atari 2600 has an 8-bit MOS 6507 CPU running at 1.19 MHz and a paltry 128 bytes of RAM. Most of the processing cycles are consumed by drawing graphics to the screen. There is no video buffer; CPU instructions must be in sync with the display, and pixel information is specified at the exact moment it is needed by the television. This means that nearly all game logic (handling joystick input, collision detection, firing missiles, sound, etc.) needs to fit into the vertical blanking (VBLANK) period when nothing is being drawn to the screen.
Unfortunately, there are not many cycles available during the VBLANK cycle because Combat needs them to, well, play Combat. To make this work, I needed more cycles than are available in an entire VBLANK, so using the leftover cycles was out of the question. My solution was to hijack the entire VBLANK for 3 frames out of each second to run my machine learning algorithm. Since the 2600 displays 30 frames per second, that still allowed the normal game logic to run 27 (out of 30) times each second. I also spread these interruptions around evenly (not consecutive frames), so they are completely transparent. No difference in response times can be detected between original Combat and Combat AI.
That gave me enough cycles, but all of the additional instructions and data could not fit in the 2 KB ROM. This was an easy fix though, the 6507 can address 4 KB ROMs, and many Atari cartridges were 4 KB in size (or even 8 KB through bank switching), so I could just modify the code to extend the ROM size. I expanded the game to 4 KB.
In order to predict the best action for the AI player to take, I needed to know the X- and Y-coordinates of both tanks. The Y-coordinates are already tracked, so that was no problem, but the Atari does not track absolute X positions of sprites. Instead, sprites are moved relative to their current position (e.g.: move 5 pixels left). To get around this, I needed to create variables to track each time an X-position was updated in any way, and keep a running total of all changes. To fit this in with the normal game logic I needed to reclaim some cycles, so I disabled engine sounds (which take a surprising amount of instructions), and a few things that were specific to non-tank game modes.
Finally, I needed to insert some code to simulate joystick inputs for player 2 based on the predictions made by the machine learning model. With the code I had already removed, I had just enough cycles to slide this in. The result is a 1-player version of Combat, in which the player 2 tank will aggressively pursue you and fire missiles in your direction when in range. I focused entirely on the tank game (variation 1), so planes and jets are not presently supported.
Media
Code
The Atari that we know and love may have went out of business many years ago, but the brand has traded hands several times since then. Since the properties have not been abandoned, I cannot post the full source code. What I will do instead is post my additions to the code, along with the byte position of the ROM that they should be inserted at (using the well-known disassembly mentioned above as the reference, so that the byte positions and label names are sure to match up). Anyone that already owns Combat can then use that disassembly as a starting point to convert it to Combat AI.
- Define the following variable names:
P0_X = $E6 P0_HM = $E7 P1_X = $E8 P1_HM = $E9 P_TEMP = $EA MIN_SCORE_LO = $EB MIN_SCORE_HI = $EC V_COUNT = $ED CUR_SCORE_LO = $EE CUR_SCORE_HI = $EF PREDICT = $F0 PREDICT_NUM = $F1
- After byte $f017, insert:
inc V_COUNT lda V_COUNT cmp #1 beq Prediction1 cmp #7 beq Prediction2 cmp #15 beq Prediction3 jmp DoNormalLogic Prediction1 JSR SCROT ; Calculate Score Offsets ; Score display gets screwed up if this ; isn't included in the logic skip frames. jsr RunPrediction ; Run K-nearest neighbor algorithm ; to calculate best heading for P1. jmp SkipNormalLogic Prediction2 JSR SCROT ; Calculate Score Offsets ; Score display gets screwed up if this ; isn't included in the logic skip frames. jsr RunPrediction2 ; Run K-nearest neighbor algorithm ; to calculate best heading for P1. jmp SkipNormalLogic Prediction3 lda #00 sta V_COUNT JSR SCROT ; Calculate Score Offsets ; Score display gets screwed up if this ; isn't included in the logic skip frames. jsr RunPrediction3 ; Run K-nearest neighbor algorithm ; to calculate best heading for P1. jmp SkipNormalLogic DoNormalLogic
- Before byte $f02c, insert:
SkipNormalLogic
- Before byte $f036, insert:
; NAB - Reset horiz. movement trackers (HMCLR above). lda #$00 sta P0_HM sta P1_HM
- Before byte $f05c, insert:
; NAB - Update player X position tracking (HMOVE above). pha lda P0_HM lsr lsr lsr lsr sta P_TEMP cmp #$08 bcs NotMovingLeftP0 ; Moving left lda P0_X sec sbc P_TEMP sta P0_X jmp DoneMovingP0 NotMovingLeftP0 ; Moving right lda #$10 sec sbc P_TEMP clc adc P0_X sta P0_X DoneMovingP0 lda P1_HM lsr lsr lsr lsr sta P_TEMP cmp #$08 bcs NotMovingLeftP1 ; Moving left lda P1_X sec sbc P_TEMP sta P1_X jmp DoneMovingP1 NotMovingLeftP1 ; Moving right lda #$10 sec sbc P_TEMP clc adc P1_X sta P1_X DoneMovingP1 pla
- Before byte $f27c, insert:
; NAB - Track horiz. movement register. cpx #$00 bne NotP0 sta P0_HM NotP0 cpx #$01 bne NotP1 sta P1_HM NotP1
- Comment out bytes $f2f6 - $f2f8
- Before byte $f320, insert:
; NAB: Adjust P1 position here. ldy PREDICT sty DIRECTN+1 cpx #$01 bne MoveNotP1 BIT GameOn ; LO nibble. BMI NoFreezeJSAuto ; Branch if game on (via bit 7). jmp MoveNotP1 NoFreezeJSAuto lda #$01 MoveNotP1
- Before byte $f3bf, insert:
; NAB: Control P1 missle launches. cpx #$01 bne DoNotAutoLaunch lda MIN_SCORE_HI bne DoNotAutoLaunch lda MIN_SCORE_LO cmp #$30 bcc DoNotAutoLaunch jmp Launch DoNotAutoLaunch
- At $f410, insert:
rts
- Comment out bytes $f3bf - $f443.
- Comment out bytes $f4e4 - f4e6.
- Comment out bytes $f53a - $f547.
- Comment out bytes $f59f - f5a6.
- Before byte $f5bd, insert:
; NAB: Initial player X positions (for tracking). lda #11 sta P0_X lda #143 sta P1_X lda #$08 sta PREDICT
- After byte $f5be, insert:
; NAB: Reset player horizontal motion trackers and vertical screen line count. sta P0_HM sta P1_HM sta V_COUNT
- After byte $f5c5, insert:
; NAB: machine learning algorithm. RunPrediction ; Find nearest neighbor. ldy #255 sty MIN_SCORE_LO sty MIN_SCORE_HI ldy #13 jmp NNloop RunPrediction2 ldy #24 jmp NNloop RunPrediction3 ldy #36 NNloop lda #0 sta CUR_SCORE_LO sta CUR_SCORE_HI ; Subtract X ; X0 lda TrainXp0,y cmp P0_X bcs X0isLess ; train < actual lda P0_X sec sbc TrainXp0,y sta CUR_SCORE_LO ; X0 difference jmp DoneX0 X0isLess sec sbc P0_X sta CUR_SCORE_LO ; X0 difference DoneX0 ; X1 lda TrainXp1,y cmp P1_X bcs X1isLess ; train < actual lda P1_X sec sbc TrainXp1,y ; X1 difference ; X0+X1 difference clc adc CUR_SCORE_LO sta CUR_SCORE_LO lda #0 adc CUR_SCORE_HI sta CUR_SCORE_HI jmp DoneX1 X1isLess sec sbc P1_X ; X1 difference ; X0+X1 difference clc adc CUR_SCORE_LO sta CUR_SCORE_LO lda #0 adc CUR_SCORE_HI sta CUR_SCORE_HI DoneX1 ; Subtract Y ; Y0 lda TrainYp0,y cmp TankY0 bcs Y0isLess ; train < actual lda TankY0 sec sbc TrainYp0,y ; Y0 difference ; X0+X1+Y0 difference clc adc CUR_SCORE_LO sta CUR_SCORE_LO lda #0 adc CUR_SCORE_HI sta CUR_SCORE_HI jmp DoneY0 Y0isLess sec sbc TankY0 ; Y0 difference ; X0+X1+Y0 difference clc adc CUR_SCORE_LO sta CUR_SCORE_LO lda #0 adc CUR_SCORE_HI sta CUR_SCORE_HI DoneY0 ; Y1 lda TrainYp1,y cmp TankY1 bcs Y1isLess ; train < actual lda TankY1 sec sbc TrainYp1,y ; Y1 difference ; X0+X1+Y0+Y1 difference clc adc CUR_SCORE_LO sta CUR_SCORE_LO lda #0 adc CUR_SCORE_HI sta CUR_SCORE_HI jmp DoneY1 Y1isLess sec sbc TankY1 ; Y1 difference ; X0+X1+Y0+Y1 difference clc adc CUR_SCORE_LO sta CUR_SCORE_LO lda #0 adc CUR_SCORE_HI sta CUR_SCORE_HI DoneY1 ; Compare current score with minimum score. ; If less, save it as the minimum and remember the prediction class. LDA CUR_SCORE_HI ; compare high bytes CMP MIN_SCORE_HI BCC ScoreLower ; if NUM1H < NUM2H then NUM1 < NUM2 BNE ScoreHigher ; if NUM1H <> NUM2H then NUM1 > NUM2 (so NUM1 >= NUM2) LDA CUR_SCORE_LO ; compare low bytes CMP MIN_SCORE_LO BCC ScoreLower ; if NUM1L < NUM2L then NUM1 < NUM2 jmp ScoreHigher ScoreLower lda CUR_SCORE_LO sta MIN_SCORE_LO lda CUR_SCORE_HI sta MIN_SCORE_HI sty PREDICT_NUM ScoreHigher dey beq DonePrediction ; For first time through. cpy #13 beq DonePrediction2 ; For second time through (second set of data). cpy #25 beq DonePrediction3 ; For third time through (third set of data). jmp NNloop DonePrediction3 ; Store best predicted direction. ldy PREDICT_NUM lda TrainClass,y sta PREDICT DonePrediction DonePrediction2 rts
- After byte $f7f4, insert:
; NAB: Training data. TrainXp0 .byte 255 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte $3e .byte $26 .byte $33 .byte $3c .byte $18 .byte $2b .byte $2a .byte $34 .byte $26 .byte $31 .byte $1c TrainYp0 .byte 255 .byte 56 .byte 56 .byte 56 .byte 56 .byte 56 .byte 95 .byte 95 .byte 95 .byte 95 .byte 95 .byte 134 .byte 134 .byte 134 .byte 134 .byte 134 .byte 173 .byte 173 .byte 173 .byte 173 .byte 173 .byte 212 .byte 212 .byte 212 .byte 212 .byte 212 .byte $4e .byte $46 .byte $70 .byte $87 .byte $64 .byte $75 .byte $7a .byte $ae .byte $83 .byte $b8 .byte $a0 TrainXp1 .byte 255 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte 148 .byte $41 .byte $5b .byte $37 .byte $29 .byte $73 .byte $5d .byte $4c .byte $4c .byte $4e .byte $1d .byte $56 TrainYp1 .byte 255 .byte 56 .byte 95 .byte 134 .byte 173 .byte 212 .byte 56 .byte 95 .byte 134 .byte 173 .byte 212 .byte 56 .byte 95 .byte 134 .byte 173 .byte 212 .byte 56 .byte 95 .byte 134 .byte 173 .byte 212 .byte 56 .byte 95 .byte 134 .byte 173 .byte 212 .byte $86 .byte $58 .byte $4d .byte $7c .byte $86 .byte $5f .byte $92 .byte $80 .byte $70 .byte $d5 .byte $71 TrainClass .byte 255 .byte 8 .byte 7 .byte 7 .byte 6 .byte 6 .byte 9 .byte 8 .byte 8 .byte 7 .byte 7 .byte 9 .byte 9 .byte 8 .byte 7 .byte 7 .byte 10 .byte 9 .byte 9 .byte 8 .byte 7 .byte 10 .byte 9 .byte 9 .byte 8 .byte 8 .byte 4 .byte 7 .byte 10 .byte 15 .byte 7 .byte 9 .byte 7 .byte 9 .byte 8 .byte 2 .byte 7
- At $f7fc, change ORG statment to:
ORG $FFFC
Bill of Materials
- 1 x Atari 2600 or emulator
About the Author
