Overview
Meshtastic can send off-grid message using inexpensive hardware to create your personal mesh.
The Station Edition series is a compact Lora device with high power PA (Maximum TX Power: 35dBm@915MHz or 868MHz for Station G1 Edition), Rugged SMA Antenna Socket, rich external IO interface, wide input voltage range (8VDC-20VDC). This series aims to provide the best RF performance in all series with credit card size and rugged construction. Fixed-location base stations and vehicle-mounted base stations are typical application scenarios for this series.
For the firmware, Meshtastic firmware 1.2.65 is preinstalled. Meshtastic Mesh Device Station Edition G1 is expected to be merged into the official meshtastic repository on Github starting from firmware 1.3.
Dimension
| Item | Description |
| Size | 10cm*5.8cm*2.1cm |
| Color | Black |
| Weight | ~80g |
Typical RF Performance
| Lora Operation Frequency | US915MHz and EU868MHz |
| Lora RF Max Output Power | 35 dBm @ US915MHz (Station Edition G1) |
| Lora Power Amplifier Gain | 21.5dB @ US915MHz (Station Edition G1) |
| Lora Power Amplifier P1dB Point | 34.5 dBm @ US915MHz (Station Edition G1) |
| Lora Power Amplifier Noise Figure | 0.96dB @ US915MHz (Station Edition G1) |
| VSWR of Lora Stock Antenna | < =2 @ 915 MHz |
Typical Application Scenarios
Station Edition could be powered by either USB Type C (PD Protocol with minimum 9V2A is required, 15V2A is recommended due to the requirements of 12V Battery Docker) or 2Pins Socket (Pitch=2.5mm, 8VDC-20VDC, 2A minimum).
Wide voltage input makes the Station Edition ideal as an vehicle-mounted base station and powered directly from the in-vehicle 12V system. The USB Type C power input allows the device to be easily powered by a USB Type C adapter which supports the PD protocol.
Ability to increase transmit power makes it possible to balance communication distance and communication speed. For low power meshtastic devices, usually necessary to set the modem to Long/Slow to obtain the required communication distance, but when using this setting, the communication speed will be very slow, and the continuous sending of messages will also cause timeouts. By increasing the transmit power, we can set the modem to Long/Fast or even Medium/Fast to get a similar experience to Internet-based instant messaging software.
More information about modem setting: https://meshtastic.org/docs/settings/channel#modem_config
Hardware
Schematics
| Schematics for 12V Battery Docker | meshtastic_mesh_device_station_edition_12v_battery_docker_28_jul_2022.pdf | Version: 28 Jul 2022 |
| Schematics for Station Edition G1 | meshtastic_mesh_device_station_edition_12_jun_2022.pdf | Version: 12 Jun 2022 |
PCB (Station Edition G1)
| No. | Description |
| 1 | ESP32 WROOM |
| 2 | Semtech SX1262 Lora Transceiver |
| 3 | Lora Power Amplifier |
| 4 | RF Switch |
| 5 | SMA Connector for Lora Antenna |
| 6 | USB Type C Socket |
| 7 | CH9102F USB to UART Bridge |
| 8 | Power Input Socket (8VDC-20VDC), 1*2P, Pitch=2.5mm |
| 9 | 7.5V DCDC |
| 10 | 3.3V DCDC |
| 11 | GPS and Notification Extension Socket, 1*5P, Pitch=1.5mm |
| 12 | IO Extension Socket, 1*10P, Pitch=1.5mm |
| 13 | LV (Low Voltage) LED Indicator |
| 14 | HV (High Voltage) LED Indicator |
| 15 | 1.3 Inch OLED Screen |
| 16 | User Button |
Power Status
| LV LED (Red) | HV LED (Green) | Description |
| ON | OFF | 3.3V DCDC is working normally, but 7.5V DCDC is not working. Generally, this status indicates the device is powered up by using USB2.0/3.0 which does not support 9V USB Type C PD protocol. For this status, everything should work normally, except the Lora PA. The firmware can be flashed into the device through Type C Port in this status. |
| ON | ON | Both 3.3V DCDC and 7.5V DCDC are working normally. Generally, this status indicates the device is powered up by 9V USB Type C PD protocol. For this status, everything should work normally. |
Mechanical Design
Similar as Nano Edition, the Station Edition is also constructed by stacking up PCB boards.This method offers a good balance of cost and mechanical strength. The Station Edition employs an aluminum substrate PCB (sliver) as heat sink for high power lora PA. Nonelectrical conductivity high performance thermal grease is applied between the heat sink and the main PCB.
Front Side and Bottom Side of the case.
RF Design - Lora (Station Edition G1)
TX PA and Antenna
Conduction Test
Instrument Setup and Device Under Test (DUT) configuration
For Instrument Setup, RF Explorer 6G Combo PLUS Spectrum Analyzer and 40 dB Attenuator was used to measure the RF transismission power. Meshtastic firmware firmware_neil_station-g1-1.2.60.bin.zip was flashed into the DUT. Meshtastic Android APP 1.2.64 had been used to control the DUT with channel options = “Long Range / Slow” and Region = “US”.
Measurements
When SX1262 TX set to 16 dBm, according to above result, the RF output power was 35.5 dBm, Gain = 19.5dB.
Repeat the measurement process with various SX1262 TX Power (TX Power Setting). The results were summarized in the follow table.
Summary for Conduction Test
| Region = “US” Center Frequency = 903.08 MHz | |||
| SX1262 TX Power Setting | PA Output Power | PA Gain | Description |
| 17 dBm | 35.5 dBm (3.55 W) | 18.5dB | |
| 16 dBm | 35.5 dBm (3.55 W) | 19.5dB | |
| 15 dBm | 35 dBm (3.16 W) | 20dB | |
| 14 dBm | 34.5 dBm (2.82 W) | 20.5dB | Recommended Setting, 1 dB Compression Point (P1dB) |
| 13 dBm | 33.5 dBm (2.24 W) | 20.5dB | |
| 12 dBm | 33 dBm (2 W) | 21dB | |
| 11 dBm | 32.5 dBm (1.78 W) | 21.5dB | |
| 10 dBm | 31.5 dBm (1.41 W) | 21.5dB | |
| 9 dBm | 30.5 dBm (1.12 W) | 21.5dB | |
| 8 dBm | 29.5 dBm (0.89 W) | 21.5dB | Default Setting, Operation with ISM band |
Accessories - 12V Battery Docker
12V Battery Docker is powered by USB TypeC with 15V PD Protocol. It has capability to charge 3*18650 Lithium Batteries with 2A MAX charging current. It also comes with multi protection features, such as Battery Temperature Monitoring, Overcharge/Overdischarge protection, Overcurrent Protection, etc.
While the Station G1 can be powered directly via USB TypeC, the 12V Battery Docker can still be used as backup power, or in scenarios that require mobility.
The motivation for designing the 12V Battery Docker is that most Power Banks cannot supply power to Station G1, because the Power Bank will automatically power off when the load is low in power consumption, especially when PD protocol is used. A few hundred mA would be considered as low in power consumption for most cases.
PCB
| No. | Description |
| 1 | 18650 Batteries |
| 2 | LED Indicator (Green) for fully charged status |
| 3 | LED Indicator (Red) for charging status |
| 4 | Li-ion Battery Protection Circuit based on XB3303A |
| 5 | NTC Thermistor, muRata NCP18XH103F03RB, 10kΩ ±1% 3380K |
| 6 | CN3703 Li-ion Battery Charger Controller |
| 7 | USB Type C Socket |
| 8 | CN1 Power Output Socket for Station G1, 1*2P, Pitch=2.5mm |
| 9 | CN3 is a duplicate of CN2 except IO35, 1*10P, Pitch=1.5mm, please refer to the schematic for more information. |
| 10 | CN2 is used to provide battery gauge function for Meshtastic if it is connected to CN2 of Station G1, 1*10P, Pitch=1.5mm |
| 11 | Power Switch for Station G1 |
Note: Green LED and Red LED flashing at the same time indicates the 12V Battery Docker is powered up by voltage lower than 15V. Generally, this status indicates that the Type C Charger does not support 15V PD Protocol.
Dimension
| Size | 10cm*9.6cm*2.7cm |
| Color | Black |
| Weight | ~65g (Without Batteries) |
Charging Experiment and Thermal Analysis
According to the charging profile in the CN3703’s datasheet, the highest temperature was expected to occur in the phase with the highest current, thus the highest temperature could be measured during the Constant Current Phase (2A for 12V Battery Docker).
For the charging experiment, three 2000 mAh 18650 Li-ion batteries was installed into 12V Battery Docker. The charging process used 1 hour and 23 minutes to charge the batteries’ voltage from 9.6V to 12.6V. About half an hour was Constant Current Phase, and the rest of the time was Constant Voltage Phase.
Thermal infrared image of the Constant Current Phase (Left) and the Constant Voltage Phase (Right), ambient temperature: 28 degrees in Celsius
Summary for Thermal Analysis
| Charging Time: 1 hour and 23 minutes, Ambient Temperature: 28 ℃ | ||
| Part No. | Constant Current Phase | Constant Voltage Phase |
| D1 | 73.1 ℃ | 36.6 ℃ |
| Q1 | 61.9 ℃ | 35.5 ℃ |
| U2,U3,U4 (XB3303A) | 51.5 ℃ | 31 ℃ |
| U1 (CN3703) | 50.8 ℃ | 35.5 ℃ |
Battery Gauge
The battery gauge will be automatically enabled within 30s if CN2 connector is connected to CN2 of Station G1.
For compatibility with Meshtastic firmware, the battery voltage has been remapped from 0V-12.6V to 0V-4.2V scale.
Details
Meshtastic firmware 1.2.x hard-coded battery characteristics at Line 160 in the Power.cpp.
const float fullVolt = 4200, emptyVolt = 3270, chargingVolt = 4210, noBatVolt = 2230;
So that, meshtastic devices were expected to work with only one Li-ion battery or batteries in parallel connection, the full charged voltage = 4.2V, empty voltage = 3.27V.
The Latest Firmware
Pre-compiled Firmware
| Version | Date | Download | Description |
| 1.2.65 | 01-Aug-2022 | firmware-station-g1-1.2.65 | Battery gauge for 12V Battery Docker is supported. Source Code |
| 1.2.60 | 28-Jun-2022 | firmware_neil_station-g1-1.2.60.bin.zip | Initial Release |
Software
Android
The Android APP could be downloaded and installed from the Google Play Store: https://play.google.com/store/apps/details?id=com.geeksville.mesh
APP Source Code: https://github.com/meshtastic/Meshtastic-Android/releases
iOS
The iOS APP could be downloaded and installed from following URL: https://meshtastic.org/docs/software/apple
JS/Python/Web Interface
Javascript, Python, Web Interface are also supported by the Meshtastic. More information: https://meshtastic.org/docs/software
Advanced Topics
TX Power Setting
For Meshtastic Firmware 1.2.x
Prerequisites
Execute following command by using Meshtastic CLI, this operation will set the SX1262 TX Power to 14 dBm:
meshtastic --ch-set tx_power 14 --ch-index 0
Output:
Connected to radio Set tx_power to 14 Writing modified channels to device
Verification, execute following command:
meshtastic --info
Output:
Connected to radio
Channels: PRIMARY psk=default { "txPower": 14, "modemConfig": "Bw125Cr48Sf4096", "psk": "AQ==" }
According to the Summary for Conduction Test, the PA Output Power is expected to be 34.5 dBm (2.82 W), after executing above command.
Real World Testing
FCC Rules and Regulations
Any RF device can transmit encrypted data in the ISM bands without license. However, the maximum transmitter power fed into the antenna should be less than or equal to 30dBm (1W).
| ISM Bands |
| 902 to 928 MHz |
| 2.400 to 2.4835 GHz |
| 5.725 to 5.875 GHz |
Benefit from high power PA even when operating in the ISM bands. For example, if there is a long coaxial cable between the transmitter and the antenna, the coaxial cable may have considerable insertion loss. At this time, the transmitting power of the transmitter can be increased to ensure exactly 30dBm power feeding into the antenna.
Reference
- FCC Rules for Unlicensed Wireless Equipment operating in the ISM bands. Retrieved Jun 1, 2022, from https://afar.net/tutorials/fcc-rules/
Operation with Amateur Radio License
Lora 915MHz is exactly 33cm band in the amateur bands. With Amateur Radio License, according to the National Association for Amateur Radio's description, the transmitter can transmit unencrypted data using up to 1500W.
This official document describes in detail how to turn off Meshtastic's encryption: Licensed (HAM) Operation.
Copyright: The National Association for Amateur Radio
Reference
- US Amateur Radio Frequency Allocations. Retrieved Jun 1, 2022, from http://www.arrl.org/frequency-allocations
- US Amateur Radio Technician Privileges. Retrieved Jun 1, 2022, from http://www.arrl.org/files/file/Tech%20Band%20Chart/US%20Amateur%20Radio%20Technician%20Privileges.pdf
- Amateur Radio Allocations and Overlapping Part 15 Bands - An Overview and a Part 97 versus Part 15 and Permissible Power Comparison. Retrieved Jun 28, 2022, from https://www.qsl.net/kb9mwr/projects/wireless/allocations.html
