Most of opcodes of brainfunk are simple sequences of simple states, that could be mixed using OR, also to select and enable buffers.
But for '[' and ']' need know a result of a test if value is zero and change the behavior from 'execute' to 'search'.
Jelly does it by using pages on eeproms, with diferent set of finite states. Simple as turn on a bit, but not.
Pages are mapped with high byte of eeprom, (in a at28c16 uses a8-a10 for 8 pages) and some logic must set and unset this bits.
------------------------------- paused, will continue
