I opted to bond the two pieces of pad back together with a large plastic sheet (icecream lid). I scored the top of the pad and plastic sheet to allow for good glue stickyness (I'm not sure it acually helped any.
I glued along the seam first
Then I attached the plastic sheet to the top. The glue didn't spread as well as I would have hoped.
Then some additional reinforcement on the back. I smushed the glue better on the last one.
Then soldered a new connector to the piezo. I think the original was a long cable, but it didn't seem to pull out enough for me to solder to it directly.
