No schematics yet. Just beleive me, it is a 6 shift registers (74hc595) connected in series, and an MCU that pushes bits into them.
There is a MCU firmware that I made, if you want you can use some code parts from there, the asm file is downloadable from files section.
There is no software emulation done by me, the firmware was tested on the real device.
dearuserhron
Henry York
Supercrab
EBP Controller
