[R] Parts to be used
A project log for Tetent TimerSpy [gd0136]
A wearable PDA / smartwatch with a Tetent [gd0090] input method.
kelvinakelvinA • 01/02/2023 at 22:43•0 Comments
Hand mount strap
I found...
GoPro mount gloves like this:
Self heating ones like this:
Flashlight holding ones like this:
And a quick release one:
Always-on display
I think, for design consistency, I should go with a square display:
There is also the idea of going with a long, rectangular one so that the screen could be angled towards my eyes (if the square one would stick out too far):
I also discovered that there's apparently a colour memory LCD in existance and it's not even that expensive, so I'm most likely going to go with this:
Main square display
To share parts and research with #T^2 TyMist [gd0138], I think that using the same square screen is the best choice. This could actually be like a project collab with myself, where I can skip past the expensive, off-the-shelf control board for TyMist because I made a custom one for TimerSpy.
This screen can go up to 120Hz and has 300 nits of brightness. There is also a much cheaper alternative version that only has 150 nits, but that's because it was tested has a 10% backlight duty cycle (something done to reduce motion blur in VR)
Solution mining... ends, in 29 days.
