[P] Designed basic concept
A project log for Tetent TimerSpy [gd0136]
A wearable PDA / smartwatch with a Tetent [gd0090] input method.
kelvinakelvinA • 02/20/2023 at 20:10•0 Comments
I've designed and printed 2 concepts. The first one was a general shape and the second one (pictured above) was moving the Finger5-to-Finger4 offset from 26mm to 21mm, adding a screen I just found and changing the back angle slope for better ergonomics.
First version:
The LPM013M126 screen I found:
This screen is rather nice because it's reflective and backlit and doesn't cost £50. I was going to try and use a 21700 when I reduced the Tetrinsic offset, but this screen would only barely fit with the 26650.
The second attempt:
The sceen is on the most ergonomic face, so I'm thinking of skipping the 2.7" screen either altogether or until I've got a working prototype and feel that I could use a larger screen.
I'm also thinking of designing the rear-hand mount such that a pocket (shown in purple) could slide inbetween the hand (brown) and the TimerSpy (grey):
That way, it shouldn't get in the way when putting my hands in pockets while still being able to slide through a sleeve.
