After a bit of trial and error, these are the settings I'm using on my Ender 3 v2 (other printers will be different):
minimum X position | 30mm |
maximum X position | 220mm |
minimum Y position | 0mm |
maximum Y position | 220mm |
Z position during cuts | 2mm (note 1) |
Z lift during travels | +4mm, i.e. Z=6mm |
Z speed | 10mm/s (note 2) |
(note 1: for paper/vinyl. Increase this accordingly for thicker materials)
(note 2: needs corresponding increase in the max Z speed, via the menus on the printer's controller)
