Polaron Build Log - 20220813
A project log for Polaron
100 TB Portable NAS that can survive the end of all things
cybermage2019Cybermage2019 • 08/14/2022 at 01:09•0 Comments
Today was just some light weight stuff.  Added EM isolation tape and kapton to all the bundles of the power supply and rerouted the power cables a little better. Did a little more work on the shaping of the case cover to get a better fit and get the lid to close air tight. Still need to lay out all the holes that need to be drilled and milled out of the base-plate
A
