With things wired on the breadboard as described in my last project log, I decided to see how things looked. I configured my ESPHome configuration to step up from 0% to 100% PWM in 10% increments. At each step, I waited for 60 seconds to give the fan speed time to stabilize. I logged the tach output every few seconds, with the fan pulse counts converted to RPMs. On the "PWM" line, I logged both the percentage from the point of view of the user and also the decimal fraction of the inverted signal, which is what is sent to the ESPHome LEDC control.
The results are in rough agreement with what I measured on my scope a few weeks ago.
PWM: 0.90 10 tach: 150 rpm tach: 164 rpm tach: 162 rpm tach: 164 rpm tach: 165 rpm tach: 161 rpm ----- PWM: 0.80 20 tach: 237 rpm tach: 362 rpm tach: 363 rpm tach: 359 rpm tach: 363 rpm tach: 362 rpm ----- PWM: 0.70 30 tach: 459 rpm tach: 620 rpm tach: 621 rpm tach: 620 rpm tach: 624 rpm tach: 620 rpm ----- PWM: 0.60 40 tach: 708 rpm tach: 851 rpm tach: 852 rpm tach: 851 rpm tach: 855 rpm tach: 854 rpm ----- PWM: 0.50 50 tach: 930 rpm tach: 1062 rpm tach: 1059 rpm tach: 1058 rpm tach: 1059 rpm tach: 1058 rpm ----- PWM: 0.40 60 tach: 1131 rpm tach: 1247 rpm tach: 1253 rpm tach: 1251 rpm tach: 1254 rpm tach: 1250 rpm ----- PWM: 0.30 70 tach: 1313 rpm tach: 1419 rpm tach: 1418 rpm tach: 1416 rpm tach: 1418 rpm tach: 1418 rpm ----- PWM: 0.20 80 tach: 1482 rpm tach: 1583 rpm tach: 1581 rpm tach: 1583 rpm tach: 1590 rpm tach: 1589 rpm ----- PWM: 0.10 90 tach: 1646 rpm tach: 1737 rpm tach: 1736 rpm tach: 1744 rpm tach: 1740 rpm tach: 1744 rpm ----- PWM: 0.00 100 tach: 1804 rpm tach: 1913 rpm tach: 1911 rpm tach: 1913 rpm tach: 1917 rpm tach: 1913 rpm
Here is a nice graphical result from a later similar test.
