I have been testing for several weeks a new circuit to create a better AC current with a current sensor to adapt the frequency.
Schematic:
![](https://cdn.hackaday.io/images/9776841669045248279.png)
By adding coil L7 and capacitor C13, the generation of alternating current is balanced in the negative and positive directions.
Old circuit:
![](https://cdn.hackaday.io/images/7087311669044884047.jpg)
New circuit:
![](https://cdn.hackaday.io/images/8209311669045410570.png)
I also added a shunt resistor to measure the current. By changing the frequency we can detect the peak of fog creation which corresponds to the current peak.
And for example for a disk sold with a resonance frequency of 108kHz the peak of fog creation is at 100kHz.
I have ordered the new PCB with the modifications. I will test it before publishing it.
