Still Roasting
A project log for Automated Coffee Bean Roaster
Roasting coffee beans at the push of a button
ben-brooksBen Brooks 01/15/2025 at 17:580 Comments
Been using the roaster for the last few years with overall good results. One thing that's definitely become obvious though, is the heating element is simply undersized for my needs. I've had to lower the fan speed a fair bit to even achieve my roast temps (and when it's cold, I have to lower the fan speed even further). This results in less agitation of the beans, which makes it more likely that some of them sit in one place too long and get slightly burnt. If we were dealing with more 'normal' temperatures, I could redesign the heating component of the roaster, but since the temps are so hot I really lack the tools or ability to make modifications to that part of the design (hence why a popcorn popper was used to begin with).
I'm still glad that I did this project and will continue to use it indefinitely, but when it eventually dies, I think I'll look into possibly just purchasing a roaster, or at the very least revisit the drawing board and see if I can find a way to increase the heating capacity (even if it's just finding a popcorn popper with a higher-wattage heating element). Having measured the power draw, even when keeping things below 15 amps I still have some room for more, not to mention if allowed myself to go all the way to 20 amps. There's also the possibility of adding some recirculation of the roasting air, but that adds a need to properly filter the air not to mention the fire hazard if some chaff makes it's way into the inlet.
I also had someone ask about the ESPHome YAML. While it's still a bit of a work-in-progress, it's mostly done. If I were starting from scratch, I'd definitely do things differently, but this was my first 'real' ESPHome project so I was still learning the nuances and best approaches to things. It's LONG as I have 3 separate roast profiles and essentially just copy-pasted things. Here's where it stands currently (with some redaction, as-needed):
esphome:
  friendly_name: Coffee Roaster
# Added because of issues with the Neopixel turning blue on startup and not working properly afterwards
  on_boot:
    priority: 500
    then:
      - climate.control:
          mode: "OFF"
          target_temperature: 15.5556°C
      - text_sensor.template.publish:
          state: "On"
      - repeat:
          count: 5
          then:
            - light.turn_off:
            - delay: 1s
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API. Changed reboot_timeout to 0s to keep it from rebooting every 15min when using away from home.
api:
  reboot_timeout: 0s
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  networks:
  - ssid: !secret wifi_ssid
    password: !secret wifi_password
  - ssid: !secret trailer_wifi_ssid
  - ssid: !secret chucks_wifi_ssid
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "Coffee-Roaster Fallback Hotspot"
#Removed so that when it can't connect to WiFi, the local AP it creates is for the web server and not setting up a different WiFi connection (i.e. allows the web server to be accessed without a WiFi network)
#captive_portal:
web_server:
  port: 80
  local: true
interval:
  - interval: 1s
    then:
    #Safety check to make sure that if the heater is on, the fan is also on
      - if:
          condition:
            and:
              - lambda: 'return id(heat_value).state > 0;'
              - fan.is_off: fan_speed
          then:
            - script.stop: roast_1
            - script.stop: roast_2
            - script.stop: roast_3
#            - script.stop: fan_mixer
            - climate.control:
                mode: "OFF"
            - fan.turn_on:
                speed: 100
                state: "ERROR: Heater On, Fan Not On"
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
                effect: "Blink"
    #Safety check to make sure that if the heater is 100% on for a while, the temperature actually increases.
      - if:
          condition:
            and:
              - lambda: 'return id(heat_value).state == 100;'
              - lambda: 'return id(heater_counter) == 0;'
              - lambda: 'return id(temp_sensor).state < 100;'
          then:
            - lambda: |-
                id(heater_start_temp) = id(temp_sensor).state;
            - lambda: |-
                id(heater_counter) = (id(heater_counter) + 1);
          else:
            - if:
                condition:
                  and:
                    - lambda: 'return id(heater_counter) > 0;'
                then:
                  - lambda: |-
                else:
                  - lambda: |-
                        id(heater_counter) = 0;
      - if:
          condition:
            and:
              - lambda: 'return id(heater_counter) > 60;'
              - lambda: 'return id(temp_sensor).state <= id(heater_start_temp);'
          then:
            - climate.control:
                mode: "OFF"
            - fan.turn_on:
                speed: 100
                state: "ERROR: Heater On, Temperature Not Increasing"
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
                effect: "Blink"
          else:
            - if:
                condition:
                then:
                  - lambda: |-
number:
#Roast #1
  - platform: template
    name: Roast 1 Preheat Temp
    optimistic: true
    device_class: temperature
    unit_of_measurement: °C
    max_value: 270
    min_value: 15
    step: 1
    initial_value: 120
    mode: box
    name: Roast 1 Temp
    optimistic: true
    max_value: 270
    min_value: 15
    step: 1
    initial_value: 221
    mode: box
    name: Roast 1 Ramp
    optimistic: true
    icon: "mdi:thermometer-chevron-up"
    unit_of_measurement: °C/min
    max_value: 120
    min_value: 1
    step: 1
    initial_value: 10
    mode: box
    name: Roast 1 Fan Speed
    optimistic: true
    icon: "mdi:fan-speed-1"
    unit_of_measurement: "%"
    max_value: 100
    min_value: 1
    step: 1
    initial_value: 75
    mode: box
#Roast #2
    name: Roast 2 Preheat Temp
    optimistic: true
    max_value: 270
    min_value: 15
    step: 1
    initial_value: 120
    mode: box
    name: Roast 2 Temp
    optimistic: true
    max_value: 270
    min_value: 15
    step: 1
    initial_value: 234
    mode: box
    name: Roast 2 Ramp
    optimistic: true
    max_value: 120
    min_value: 1
    step: 1
    initial_value: 8
    mode: box
    name: Roast 2 Fan Speed
    optimistic: true
    icon: "mdi:fan-speed-2"
    max_value: 100
    min_value: 1
    step: 1
    initial_value: 75
    mode: box
#Roast #3
    name: Roast 3 Preheat Temp
    optimistic: true
    max_value: 270
    min_value: 15
    step: 1
    initial_value: 120
    mode: box
    name: Roast 3 Temp
    optimistic: true
    max_value: 270
    min_value: 15
    step: 1
    initial_value: 221
    mode: box
    name: Roast 3 Ramp
    optimistic: true
    max_value: 120
    min_value: 1
    step: 1
    initial_value: 10
    mode: box
    name: Roast 3 Fan Speed
    optimistic: true
    icon: "mdi:fan-speed-3"
    max_value: 100
    min_value: 1
    step: 1
    initial_value: 50
    mode: box
button:
#Roast #1
    name: "Start Roast #1"
    icon: "mdi:coffee"
    on_press:
        then:
            - if:
                condition:
                  lambda: 'return (id(currently_roasting) == 1);'
                then:
                else:
                    - script.execute: roast_1
#Roast #2
    name: "Start Roast #2"
    icon: "mdi:coffee"
    on_press:
        then:
            - if:
                condition:
                then:
                else:
                    - script.execute: roast_2
#Roast #3
    name: "Start Roast #3"
    icon: "mdi:coffee"
    on_press:
        then:
            - if:
                condition:
                then:
                else:
                    - script.execute: roast_3
globals:
    - id: currently_roasting
      type: int
      restore_value: no
      initial_value: '0'
    - id: current_temp_setpoint
      type: int
      restore_value: no
      initial_value: '0'
    #Used for heater safety interval check
    - id: heater_counter
      type: int
      restore_value: no
      initial_value: '0'
    - id: heater_start_temp
      type: int
      restore_value: no
      initial_value: '0'
script:
  - id: reduce_fan_speed
    mode: restart
    then:
      - delay: 30s
      - fan.turn_on:
          speed: 50
      - delay: 20s
      - fan.turn_on:
          speed: 40
      - delay: 20s
      - fan.turn_on:
          speed: 30
  - id: roast_timer
    mode: restart
    then:
      - delay: 2700s
      - climate.control:
          mode: "OFF"
      - fan.turn_on:
          speed: 100
          state: "ERROR: Roast Timeout"
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 0%
          blue: 0%
          effect: "Blink"
  - id: roast_1
    then:
      - globals.set:
          value: '1'
#      - globals.set:
#          id: current_fan_speed
#          value: !lambda |-
#                                return id(roast_1_fan_speed).state;
      - light.turn_on:
      - light.turn_off:
      - light.turn_off:
      - light.turn_on:
          brightness: 50%
          red: 100%
          green: 100%
          blue: 0%
      - fan.turn_on:
          speed: !lambda |-
      - delay: 5s
      - climate.control:
         mode: HEAT
         target_temperature: !lambda |-
                                return id(roast_1_preheat_temp).state;
          state: "Roast #1 Preheat"
      - wait_until:
          condition:
            lambda: |-
              return id(temp_sensor).state > (id(roast_1_preheat_temp).state - 1);
          timeout: 300s
      - if:
          condition:
            - lambda: |-
                return id(temp_sensor).state < (id(roast_1_preheat_temp).state - 1);
          then:
            - climate.control:
                mode: "OFF"
            - fan.turn_on:
                speed: 100
                state: "ERROR: Preheat Timeout"
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
                effect: "Blink"
          else:
      - delay: 120s
#      - script.execute: fan_mixer
      - light.turn_on:
          brightness: 50%
          red: 100%
          green: 0%
          blue: 0%
      - globals.set:
                  value: !lambda |-
      - script.execute: roast_timer
          state: "Roast #1 Ramp-up"
      - while:
          condition:
            or:
              - lambda: |-
                  return id(temp_sensor).state < id(roast_1_temp).state;
#Was having issues with the roast ending early but not throwing errors. Changed from AND to OR above and added this to try at catch a situation where the temp sensor doesn't read a number (i.e. so it ISN'T less than the roast temp).
              - lambda: |-
                  return isnan(id(temp_sensor).state);
          then:
              - climate.control:
                  mode: HEAT
                      return id(current_temp_setpoint);
              # delay will be calculated by dividing 60 by C/min value
              - delay: !lambda |-
                            return 60000 / id(roast_1_ramp).state;
              - if:
                  condition:
                    - lambda: |-
                        return id(current_temp_setpoint) == id(roast_1_temp).state;
                  then:
                    - script.execute: reduce_fan_speed
                  else:
              - if:
                  condition:
                    - lambda: |-
                        return id(current_temp_setpoint) < id(roast_1_temp).state;
                  then:
                    - lambda: |-
                        id(current_temp_setpoint) = (id(current_temp_setpoint) + 1);
                  else:
      - script.stop: roast_timer
      - script.stop: reduce_fan_speed
      - light.turn_on:
          brightness: 50%
          red: 100%
          green: 65%
          blue: 0%
      - climate.control:
          mode: "OFF"
      - fan.turn_on:
          speed: 100
          state: "Roast #1 Cooldown"
      - wait_until:
          condition:
              sensor.in_range:
                  below: 40
          timeout: 1200s
      - delay: 60s
      - fan.turn_off: fan_speed
      - globals.set:
          value: '0'
          state: "Roast #1 Done"
      - light.turn_on:
          brightness: 50%
          red: 0%
          green: 100%
          blue: 0%
  - id: roast_2
    then:
      - globals.set:
          value: '1'
      - light.turn_on:
      - light.turn_off:
      - light.turn_off:
      - light.turn_on:
          brightness: 50%
          red: 100%
          green: 100%
          blue: 0%
      - fan.turn_on:
          speed: !lambda |-
                                return id(roast_2_fan_speed).state;
      - delay: 5s
      - climate.control:
         mode: HEAT
                                return id(roast_2_preheat_temp).state;
          state: "Roast #2 Preheat"
      - wait_until:
          condition:
            lambda: |-
              return id(temp_sensor).state > (id(roast_2_preheat_temp).state - 1);
          timeout: 300s
      - if:
          condition:
            - lambda: |-
                return id(temp_sensor).state < (id(roast_2_preheat_temp).state - 1);
          then:
            - climate.control:
                mode: "OFF"
            - fan.turn_on:
                speed: 100
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
                effect: "Blink"
          else:
      - delay: 120s
      - light.turn_on:
          brightness: 50%
          red: 100%
          green: 0%
          blue: 0%
      - globals.set:
                  value: !lambda |-
          state: "Roast #2 Ramp-up"
      - while:
          condition:
            or:
              - lambda: |-
                  return id(temp_sensor).state < id(roast_2_temp).state;
              - lambda: |-
          then:
              - climate.control:
                  mode: HEAT
              - delay: !lambda |-
                            return 60000 / id(roast_2_ramp).state;
              - if:
                  condition:
                    - lambda: |-
                        return id(current_temp_setpoint) == id(roast_2_temp).state;
                  then:
                  else:
              - if:
                  condition:
                    - lambda: |-
                        return id(current_temp_setpoint) < id(roast_2_temp).state;
                  then:
                    - lambda: |-
                  else:
      - light.turn_on:
          brightness: 50%
          red: 100%
          green: 65%
          blue: 0%
      - climate.control:
          mode: "OFF"
      - fan.turn_on:
          speed: 100
          state: "Roast #2 Cooldown"
      - wait_until:
          condition:
              sensor.in_range:
                  below: 40
          timeout: 1200s
      - delay: 60s
      - globals.set:
          value: '0'
          state: "Roast #2 Done"
      - light.turn_on:
          brightness: 50%
          red: 0%
          green: 100%
          blue: 0%
  - id: roast_3
    then:
      - globals.set:
          value: '1'
      - light.turn_on:
      - light.turn_off:
      - light.turn_off:
      - light.turn_on:
          brightness: 50%
          red: 100%
          green: 100%
          blue: 0%
      - fan.turn_on:
          speed: !lambda |-
                                return id(roast_3_fan_speed).state;
      - delay: 5s
      - climate.control:
         mode: HEAT
                                return id(roast_3_preheat_temp).state;
          state: "Roast #3 Preheat"
      - wait_until:
          condition:
            lambda: |-
              return id(temp_sensor).state > (id(roast_3_preheat_temp).state - 1);
          timeout: 300s
      - if:
          condition:
            - lambda: |-
                return id(temp_sensor).state < (id(roast_3_preheat_temp).state - 1);
          then:
            - climate.control:
                mode: "OFF"
            - fan.turn_on:
                speed: 100
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
                effect: "Blink"
          else:
#Shortened from 120s to 30s to reduce energy usage while in trailer
      - delay: 30s
      - light.turn_on:
          brightness: 50%
          red: 100%
          green: 0%
          blue: 0%
      - globals.set:
                  value: !lambda |-
          state: "Roast #3 Ramp-up"
      - while:
          condition:
            or:
              - lambda: |-
                  return id(temp_sensor).state < id(roast_3_temp).state;
              - lambda: |-
          then:
              - climate.control:
                  mode: HEAT
              - delay: !lambda |-
                            return 60000 / id(roast_3_ramp).state;
              - if:
                  condition:
                    - lambda: |-
                        return id(current_temp_setpoint) == id(roast_3_temp).state;
                  then:
                  else:
              - if:
                  condition:
                    - lambda: |-
                        return id(current_temp_setpoint) < id(roast_3_temp).state;
                  then:
                    - lambda: |-
                  else:
      - light.turn_on:
          brightness: 50%
          red: 100%
          green: 65%
          blue: 0%
      - climate.control:
          mode: "OFF"
      - fan.turn_on:
          speed: 100
          state: "Roast #3 Cooldown"
      - wait_until:
          condition:
              sensor.in_range:
                  below: 40
          timeout: 1200s
      - delay: 60s
      - globals.set:
          value: '0'
          state: "Roast #3 Done"
      - light.turn_on:
          brightness: 50%
          red: 0%
          green: 100%
          blue: 0%
  - id: blank_script
    then:
light:
  - platform: binary
    name: Button Light 1
    output: button_light_1
    restore_mode: ALWAYS_OFF
  - platform: binary
    name: Button Light 2
    output: button_light_2
  - platform: binary
    name: Button Light 3
    output: button_light_3
  - platform: neopixelbus
    type: RGB
    variant: SK6812
    pin: GPIO22
    num_leds: 1
    default_transition_length: 0s
    effects:
      - pulse:
          update_interval: 1s
binary_sensor:
  - platform: gpio
    pin:
        number: GPIO27
        inverted: true
        mode:
            input: true
            pullup: true
    on_press:
        then:
            - if:
                condition:
                then:
                else:
  - platform: gpio
    pin:
        number: GPIO32
        inverted: true
        mode:
            input: true
            pullup: true
    on_press:
        then:
            - if:
                condition:
                then:
                else:
  - platform: gpio
    pin:
        number: GPIO33
        inverted: true
        mode:
            input: true
            pullup: true
    on_press:
        then:
            - if:
                condition:
                then:
                else:
output:
  - id: button_light_1
    platform: gpio
    pin: GPIO4
  - id: button_light_2
    platform: gpio
    pin: GPIO25
  - id: button_light_3
    platform: gpio
    pin: GPIO26
  - platform: ledc
    pin: GPIO16
    frequency: 1000 Hz #might need to change to get it to work?
    min_power: 0.2
    zero_means_zero: true
  - platform: slow_pwm
    pin: GPIO17
    period: 15s
    turn_on_action:
      - fan.turn_on:
    #Required this action and leaving it blank threw errors, so I just made a script to call that does nothing.
    turn_off_action:
      - script.execute: blank_script
fan:
  - platform: speed
    output: fan_pwm
climate:
  - platform: pid
    name: PID Controller
    sensor: temp_sensor
    default_target_temperature: 15.5556°C
    heat_output: heater_pwm
    control_parameters:
      kp: 0.07276 #0.05009
      ki: 0.00364 #0.00230
      kd: 0.36376 #0.27302
    visual:
      min_temperature: 15.5556°C
      max_temperature: 270°C
      temperature_step: 1°C
switch:
    name: PID Controller Autotune
    turn_on_action:
      - climate.pid.autotune: pid_controller
spi:
  clk_pin: GPIO14 #14 #18
  mosi_pin: GPIO13 #13 #23
  miso_pin: GPIO12 #12 #19
sensor:
  - platform: max31855
    cs_pin: GPIO15 #15 #5
    update_interval: 1s
    #filters:
    #  - lambda: return x * (9.0/5.0) + 32.0;
    #unit_of_measurement: "°F"
    on_value_range:
      - above: 280
        then:
          - climate.control:
              mode: "OFF"
          - fan.turn_on:
              speed: 100
              state: "ERROR: OVERHEAT PROTECTION"
          - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
                effect: "Blink"
  - platform: wifi_signal
    update_interval: 60s
    disabled_by_default: true
  - platform: uptime
  - platform: pid
    type: KP
  - platform: pid
    type: KI
  - platform: pid
    type: KD
  - platform: pid
    type: HEAT
#heat_value is a percent but the state reports back 0-100, not 0-1
#Used a power meter to get the power draw at the various settings
    unit_of_measurement: "W"
    device_class: "power"
    lambda: |-
      if (id(fan_speed).state) {
        return 1 + 57.5 + (id(heat_value).state)*13.805;
      } else {
        return 1;
    update_interval: 1s
# Progress indicator sensors
    name: "Roast Progress"
    lambda: |-
      if (id(roast_timer).is_running() and id(roast_1).is_running()) {
        return (id(roast_1_percent_complete).state);
      } else if (id(roast_timer).is_running() and id(roast_2).is_running()){
        return (id(roast_2_percent_complete).state);
      } else if (id(roast_timer).is_running() and id(roast_3).is_running()){
        return (id(roast_3_percent_complete).state);
      } else if ((id(roast_status).state == "Roast #1 Done") or (id(roast_status).state == "Roast #2 Done") or (id(roast_status).state == "Roast #3 Done") or (id(roast_status).state == "Roast #1 Cooldown") or (id(roast_status).state == "Roast #2 Cooldown") or (id(roast_status).state == "Roast #3 Cooldown") ){
          return 100;
      } else {
        return 0;
    update_interval: 5s
    icon: mdi:timer-sand
    accuracy_decimals: 0
    name: "Roast #1 Percent Complete"
    lambda: return (id(temp_sensor).state);
    update_interval: 5s
    internal: true
    filters:
      - calibrate_linear:
         method: least_squares
         datapoints:
          - 120 -> 0
          - 221 -> 100
      - clamp:
          min_value: 0
          max_value: 100
    name: "Roast #2 Percent Complete"
    update_interval: 5s
    internal: true
    filters:
      - calibrate_linear:
         datapoints:
          - 120 -> 0
          - 234 -> 100
      - clamp:
          min_value: 0
          max_value: 100
    name: "Roast #3 Percent Complete"
    update_interval: 5s
    internal: true
    filters:
      - calibrate_linear:
         datapoints:
          - 120 -> 0
          - 221 -> 100
      - clamp:
          min_value: 0
          max_value: 100
text_sensor:
  - platform: wifi_info
    ip_address:
    icon: "mdi:card-text"
status_led:
  pin:
    number: GPIO2
    inverted: false
