Been using the roaster for the last few years with overall good results. One thing that's definitely become obvious though, is the heating element is simply undersized for my needs. I've had to lower the fan speed a fair bit to even achieve my roast temps (and when it's cold, I have to lower the fan speed even further). This results in less agitation of the beans, which makes it more likely that some of them sit in one place too long and get slightly burnt. If we were dealing with more 'normal' temperatures, I could redesign the heating component of the roaster, but since the temps are so hot I really lack the tools or ability to make modifications to that part of the design (hence why a popcorn popper was used to begin with).
I'm still glad that I did this project and will continue to use it indefinitely, but when it eventually dies, I think I'll look into possibly just purchasing a roaster, or at the very least revisit the drawing board and see if I can find a way to increase the heating capacity (even if it's just finding a popcorn popper with a higher-wattage heating element). Having measured the power draw, even when keeping things below 15 amps I still have some room for more, not to mention if allowed myself to go all the way to 20 amps. There's also the possibility of adding some recirculation of the roasting air, but that adds a need to properly filter the air not to mention the fire hazard if some chaff makes it's way into the inlet.
I also had someone ask about the ESPHome YAML. While it's still a bit of a work-in-progress, it's mostly done. If I were starting from scratch, I'd definitely do things differently, but this was my first 'real' ESPHome project so I was still learning the nuances and best approaches to things. It's LONG as I have 3 separate roast profiles and essentially just copy-pasted things. Here's where it stands currently (with some redaction, as-needed):
esphome:
friendly_name: Coffee Roaster
# Added because of issues with the Neopixel turning blue on startup and not working properly afterwards
on_boot:
priority: 500
then:
- climate.control:
mode: "OFF"
target_temperature: 15.5556°C
- text_sensor.template.publish:
state: "On"
- repeat:
count: 5
then:
- light.turn_off:
- delay: 1s
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API. Changed reboot_timeout to 0s to keep it from rebooting every 15min when using away from home.
api:
reboot_timeout: 0s
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
- platform: esphome
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
networks:
- ssid: !secret wifi_ssid
password: !secret wifi_password
- ssid: !secret trailer_wifi_ssid
- ssid: !secret chucks_wifi_ssid
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "Coffee-Roaster Fallback Hotspot"
#Removed so that when it can't connect to WiFi, the local AP it creates is for the web server and not setting up a different WiFi connection (i.e. allows the web server to be accessed without a WiFi network)
#captive_portal:
web_server:
port: 80
local: true
interval:
- interval: 1s
then:
#Safety check to make sure that if the heater is on, the fan is also on
- if:
condition:
and:
- lambda: 'return id(heat_value).state > 0;'
- fan.is_off: fan_speed
then:
- script.stop: roast_1
- script.stop: roast_2
- script.stop: roast_3
# - script.stop: fan_mixer
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
state: "ERROR: Heater On, Fan Not On"
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
effect: "Blink"
#Safety check to make sure that if the heater is 100% on for a while, the temperature actually increases.
- if:
condition:
and:
- lambda: 'return id(heat_value).state == 100;'
- lambda: 'return id(heater_counter) == 0;'
- lambda: 'return id(temp_sensor).state < 100;'
then:
- lambda: |-
id(heater_start_temp) = id(temp_sensor).state;
- lambda: |-
id(heater_counter) = (id(heater_counter) + 1);
else:
- if:
condition:
and:
- lambda: 'return id(heater_counter) > 0;'
then:
- lambda: |-
else:
- lambda: |-
id(heater_counter) = 0;
- if:
condition:
and:
- lambda: 'return id(heater_counter) > 60;'
- lambda: 'return id(temp_sensor).state <= id(heater_start_temp);'
then:
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
state: "ERROR: Heater On, Temperature Not Increasing"
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
effect: "Blink"
else:
- if:
condition:
then:
- lambda: |-
number:
#Roast #1
- platform: template
name: Roast 1 Preheat Temp
optimistic: true
device_class: temperature
unit_of_measurement: °C
max_value: 270
min_value: 15
step: 1
initial_value: 120
mode: box
name: Roast 1 Temp
optimistic: true
max_value: 270
min_value: 15
step: 1
initial_value: 221
mode: box
name: Roast 1 Ramp
optimistic: true
icon: "mdi:thermometer-chevron-up"
unit_of_measurement: °C/min
max_value: 120
min_value: 1
step: 1
initial_value: 10
mode: box
name: Roast 1 Fan Speed
optimistic: true
icon: "mdi:fan-speed-1"
unit_of_measurement: "%"
max_value: 100
min_value: 1
step: 1
initial_value: 75
mode: box
#Roast #2
name: Roast 2 Preheat Temp
optimistic: true
max_value: 270
min_value: 15
step: 1
initial_value: 120
mode: box
name: Roast 2 Temp
optimistic: true
max_value: 270
min_value: 15
step: 1
initial_value: 234
mode: box
name: Roast 2 Ramp
optimistic: true
max_value: 120
min_value: 1
step: 1
initial_value: 8
mode: box
name: Roast 2 Fan Speed
optimistic: true
icon: "mdi:fan-speed-2"
max_value: 100
min_value: 1
step: 1
initial_value: 75
mode: box
#Roast #3
name: Roast 3 Preheat Temp
optimistic: true
max_value: 270
min_value: 15
step: 1
initial_value: 120
mode: box
name: Roast 3 Temp
optimistic: true
max_value: 270
min_value: 15
step: 1
initial_value: 221
mode: box
name: Roast 3 Ramp
optimistic: true
max_value: 120
min_value: 1
step: 1
initial_value: 10
mode: box
name: Roast 3 Fan Speed
optimistic: true
icon: "mdi:fan-speed-3"
max_value: 100
min_value: 1
step: 1
initial_value: 50
mode: box
button:
#Roast #1
name: "Start Roast #1"
icon: "mdi:coffee"
on_press:
then:
- if:
condition:
lambda: 'return (id(currently_roasting) == 1);'
then:
else:
- script.execute: roast_1
#Roast #2
name: "Start Roast #2"
icon: "mdi:coffee"
on_press:
then:
- if:
condition:
then:
else:
- script.execute: roast_2
#Roast #3
name: "Start Roast #3"
icon: "mdi:coffee"
on_press:
then:
- if:
condition:
then:
else:
- script.execute: roast_3
globals:
- id: currently_roasting
type: int
restore_value: no
initial_value: '0'
- id: current_temp_setpoint
type: int
restore_value: no
initial_value: '0'
#Used for heater safety interval check
- id: heater_counter
type: int
restore_value: no
initial_value: '0'
- id: heater_start_temp
type: int
restore_value: no
initial_value: '0'
script:
- id: reduce_fan_speed
mode: restart
then:
- delay: 30s
- fan.turn_on:
speed: 50
- delay: 20s
- fan.turn_on:
speed: 40
- delay: 20s
- fan.turn_on:
speed: 30
- id: roast_timer
mode: restart
then:
- delay: 2700s
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
state: "ERROR: Roast Timeout"
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
effect: "Blink"
- id: roast_1
then:
- globals.set:
value: '1'
# - globals.set:
# id: current_fan_speed
# value: !lambda |-
# return id(roast_1_fan_speed).state;
- light.turn_on:
- light.turn_off:
- light.turn_off:
- light.turn_on:
brightness: 50%
red: 100%
green: 100%
blue: 0%
- fan.turn_on:
speed: !lambda |-
- delay: 5s
- climate.control:
mode: HEAT
target_temperature: !lambda |-
return id(roast_1_preheat_temp).state;
state: "Roast #1 Preheat"
- wait_until:
condition:
lambda: |-
return id(temp_sensor).state > (id(roast_1_preheat_temp).state - 1);
timeout: 300s
- if:
condition:
- lambda: |-
return id(temp_sensor).state < (id(roast_1_preheat_temp).state - 1);
then:
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
state: "ERROR: Preheat Timeout"
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
effect: "Blink"
else:
- delay: 120s
# - script.execute: fan_mixer
- light.turn_on:
brightness: 50%
red: 100%
green: 0%
blue: 0%
- globals.set:
value: !lambda |-
- script.execute: roast_timer
state: "Roast #1 Ramp-up"
- while:
condition:
or:
- lambda: |-
return id(temp_sensor).state < id(roast_1_temp).state;
#Was having issues with the roast ending early but not throwing errors. Changed from AND to OR above and added this to try at catch a situation where the temp sensor doesn't read a number (i.e. so it ISN'T less than the roast temp).
- lambda: |-
return isnan(id(temp_sensor).state);
then:
- climate.control:
mode: HEAT
return id(current_temp_setpoint);
# delay will be calculated by dividing 60 by C/min value
- delay: !lambda |-
return 60000 / id(roast_1_ramp).state;
- if:
condition:
- lambda: |-
return id(current_temp_setpoint) == id(roast_1_temp).state;
then:
- script.execute: reduce_fan_speed
else:
- if:
condition:
- lambda: |-
return id(current_temp_setpoint) < id(roast_1_temp).state;
then:
- lambda: |-
id(current_temp_setpoint) = (id(current_temp_setpoint) + 1);
else:
- script.stop: roast_timer
- script.stop: reduce_fan_speed
- light.turn_on:
brightness: 50%
red: 100%
green: 65%
blue: 0%
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
state: "Roast #1 Cooldown"
- wait_until:
condition:
sensor.in_range:
below: 40
timeout: 1200s
- delay: 60s
- fan.turn_off: fan_speed
- globals.set:
value: '0'
state: "Roast #1 Done"
- light.turn_on:
brightness: 50%
red: 0%
green: 100%
blue: 0%
- id: roast_2
then:
- globals.set:
value: '1'
- light.turn_on:
- light.turn_off:
- light.turn_off:
- light.turn_on:
brightness: 50%
red: 100%
green: 100%
blue: 0%
- fan.turn_on:
speed: !lambda |-
return id(roast_2_fan_speed).state;
- delay: 5s
- climate.control:
mode: HEAT
return id(roast_2_preheat_temp).state;
state: "Roast #2 Preheat"
- wait_until:
condition:
lambda: |-
return id(temp_sensor).state > (id(roast_2_preheat_temp).state - 1);
timeout: 300s
- if:
condition:
- lambda: |-
return id(temp_sensor).state < (id(roast_2_preheat_temp).state - 1);
then:
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
effect: "Blink"
else:
- delay: 120s
- light.turn_on:
brightness: 50%
red: 100%
green: 0%
blue: 0%
- globals.set:
value: !lambda |-
state: "Roast #2 Ramp-up"
- while:
condition:
or:
- lambda: |-
return id(temp_sensor).state < id(roast_2_temp).state;
- lambda: |-
then:
- climate.control:
mode: HEAT
- delay: !lambda |-
return 60000 / id(roast_2_ramp).state;
- if:
condition:
- lambda: |-
return id(current_temp_setpoint) == id(roast_2_temp).state;
then:
else:
- if:
condition:
- lambda: |-
return id(current_temp_setpoint) < id(roast_2_temp).state;
then:
- lambda: |-
else:
- light.turn_on:
brightness: 50%
red: 100%
green: 65%
blue: 0%
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
state: "Roast #2 Cooldown"
- wait_until:
condition:
sensor.in_range:
below: 40
timeout: 1200s
- delay: 60s
- globals.set:
value: '0'
state: "Roast #2 Done"
- light.turn_on:
brightness: 50%
red: 0%
green: 100%
blue: 0%
- id: roast_3
then:
- globals.set:
value: '1'
- light.turn_on:
- light.turn_off:
- light.turn_off:
- light.turn_on:
brightness: 50%
red: 100%
green: 100%
blue: 0%
- fan.turn_on:
speed: !lambda |-
return id(roast_3_fan_speed).state;
- delay: 5s
- climate.control:
mode: HEAT
return id(roast_3_preheat_temp).state;
state: "Roast #3 Preheat"
- wait_until:
condition:
lambda: |-
return id(temp_sensor).state > (id(roast_3_preheat_temp).state - 1);
timeout: 300s
- if:
condition:
- lambda: |-
return id(temp_sensor).state < (id(roast_3_preheat_temp).state - 1);
then:
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
effect: "Blink"
else:
#Shortened from 120s to 30s to reduce energy usage while in trailer
- delay: 30s
- light.turn_on:
brightness: 50%
red: 100%
green: 0%
blue: 0%
- globals.set:
value: !lambda |-
state: "Roast #3 Ramp-up"
- while:
condition:
or:
- lambda: |-
return id(temp_sensor).state < id(roast_3_temp).state;
- lambda: |-
then:
- climate.control:
mode: HEAT
- delay: !lambda |-
return 60000 / id(roast_3_ramp).state;
- if:
condition:
- lambda: |-
return id(current_temp_setpoint) == id(roast_3_temp).state;
then:
else:
- if:
condition:
- lambda: |-
return id(current_temp_setpoint) < id(roast_3_temp).state;
then:
- lambda: |-
else:
- light.turn_on:
brightness: 50%
red: 100%
green: 65%
blue: 0%
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
state: "Roast #3 Cooldown"
- wait_until:
condition:
sensor.in_range:
below: 40
timeout: 1200s
- delay: 60s
- globals.set:
value: '0'
state: "Roast #3 Done"
- light.turn_on:
brightness: 50%
red: 0%
green: 100%
blue: 0%
- id: blank_script
then:
light:
- platform: binary
name: Button Light 1
output: button_light_1
restore_mode: ALWAYS_OFF
- platform: binary
name: Button Light 2
output: button_light_2
- platform: binary
name: Button Light 3
output: button_light_3
- platform: neopixelbus
type: RGB
variant: SK6812
pin: GPIO22
num_leds: 1
default_transition_length: 0s
effects:
- pulse:
update_interval: 1s
binary_sensor:
- platform: gpio
pin:
number: GPIO27
inverted: true
mode:
input: true
pullup: true
on_press:
then:
- if:
condition:
then:
else:
- platform: gpio
pin:
number: GPIO32
inverted: true
mode:
input: true
pullup: true
on_press:
then:
- if:
condition:
then:
else:
- platform: gpio
pin:
number: GPIO33
inverted: true
mode:
input: true
pullup: true
on_press:
then:
- if:
condition:
then:
else:
output:
- id: button_light_1
platform: gpio
pin: GPIO4
- id: button_light_2
platform: gpio
pin: GPIO25
- id: button_light_3
platform: gpio
pin: GPIO26
- platform: ledc
pin: GPIO16
frequency: 1000 Hz #might need to change to get it to work?
min_power: 0.2
zero_means_zero: true
- platform: slow_pwm
pin: GPIO17
period: 15s
turn_on_action:
- fan.turn_on:
#Required this action and leaving it blank threw errors, so I just made a script to call that does nothing.
turn_off_action:
- script.execute: blank_script
fan:
- platform: speed
output: fan_pwm
climate:
- platform: pid
name: PID Controller
sensor: temp_sensor
default_target_temperature: 15.5556°C
heat_output: heater_pwm
control_parameters:
kp: 0.07276 #0.05009
ki: 0.00364 #0.00230
kd: 0.36376 #0.27302
visual:
min_temperature: 15.5556°C
max_temperature: 270°C
temperature_step: 1°C
switch:
name: PID Controller Autotune
turn_on_action:
- climate.pid.autotune: pid_controller
spi:
clk_pin: GPIO14 #14 #18
mosi_pin: GPIO13 #13 #23
miso_pin: GPIO12 #12 #19
sensor:
- platform: max31855
cs_pin: GPIO15 #15 #5
update_interval: 1s
#filters:
# - lambda: return x * (9.0/5.0) + 32.0;
#unit_of_measurement: "°F"
on_value_range:
- above: 280
then:
- climate.control:
mode: "OFF"
- fan.turn_on:
speed: 100
state: "ERROR: OVERHEAT PROTECTION"
- light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
effect: "Blink"
- platform: wifi_signal
update_interval: 60s
disabled_by_default: true
- platform: uptime
- platform: pid
type: KP
- platform: pid
type: KI
- platform: pid
type: KD
- platform: pid
type: HEAT
#heat_value is a percent but the state reports back 0-100, not 0-1
#Used a power meter to get the power draw at the various settings
unit_of_measurement: "W"
device_class: "power"
lambda: |-
if (id(fan_speed).state) {
return 1 + 57.5 + (id(heat_value).state)*13.805;
} else {
return 1;
update_interval: 1s
# Progress indicator sensors
name: "Roast Progress"
lambda: |-
if (id(roast_timer).is_running() and id(roast_1).is_running()) {
return (id(roast_1_percent_complete).state);
} else if (id(roast_timer).is_running() and id(roast_2).is_running()){
return (id(roast_2_percent_complete).state);
} else if (id(roast_timer).is_running() and id(roast_3).is_running()){
return (id(roast_3_percent_complete).state);
} else if ((id(roast_status).state == "Roast #1 Done") or (id(roast_status).state == "Roast #2 Done") or (id(roast_status).state == "Roast #3 Done") or (id(roast_status).state == "Roast #1 Cooldown") or (id(roast_status).state == "Roast #2 Cooldown") or (id(roast_status).state == "Roast #3 Cooldown") ){
return 100;
} else {
return 0;
update_interval: 5s
icon: mdi:timer-sand
accuracy_decimals: 0
name: "Roast #1 Percent Complete"
lambda: return (id(temp_sensor).state);
update_interval: 5s
internal: true
filters:
- calibrate_linear:
method: least_squares
datapoints:
- 120 -> 0
- 221 -> 100
- clamp:
min_value: 0
max_value: 100
name: "Roast #2 Percent Complete"
update_interval: 5s
internal: true
filters:
- calibrate_linear:
datapoints:
- 120 -> 0
- 234 -> 100
- clamp:
min_value: 0
max_value: 100
name: "Roast #3 Percent Complete"
update_interval: 5s
internal: true
filters:
- calibrate_linear:
datapoints:
- 120 -> 0
- 221 -> 100
- clamp:
min_value: 0
max_value: 100
text_sensor:
- platform: wifi_info
ip_address:
icon: "mdi:card-text"
status_led:
pin:
number: GPIO2
inverted: false
