I apologise. I neglected these logs during development. It's not you, it's me.
I'm not going to go into detail about the development process. I finished building Nagini in August 2023. Full in depth details of the build process can be found at the Esk8 forum. Instead, here are some photos (in no particular order).
The deck:
![](https://cdn.hackaday.io/images/1865761713088597066.jpg)
![](https://cdn.hackaday.io/images/6727691713088603318.jpg)
![](https://cdn.hackaday.io/images/6482781713088605368.jpg)
![](https://cdn.hackaday.io/images/1029061713088606694.jpg)
![](https://cdn.hackaday.io/images/9207221713088606869.jpg)
![](https://cdn.hackaday.io/images/6851521713088607689.jpg)
The motor mounts:
![](https://cdn.hackaday.io/images/7709811713088702314.jpg)
![](https://cdn.hackaday.io/images/4978131713088706387.jpg)
The battery:
![](https://cdn.hackaday.io/images/9126801713088887171.jpg)
![](https://cdn.hackaday.io/images/6660231713088889957.jpg)
![](https://cdn.hackaday.io/images/2904831713088890322.jpg)
![](https://cdn.hackaday.io/images/7538971713088891147.jpg)
![](https://cdn.hackaday.io/images/2626691713088949167.jpg)
![](https://cdn.hackaday.io/images/4954731713088953078.jpg)
![](https://cdn.hackaday.io/images/1748811713088955037.jpg)
The enclosure (this was a nightmare)
![](https://cdn.hackaday.io/images/2322511713089165300.jpg)
![](https://cdn.hackaday.io/images/6454201713089165549.jpg)
![](https://cdn.hackaday.io/images/6368231713089166167.jpg)
![](https://cdn.hackaday.io/images/6155891713089169348.jpg)
![](https://cdn.hackaday.io/images/4832011713089173339.jpg)
![](https://cdn.hackaday.io/images/1836791713089173449.jpg)
![](https://cdn.hackaday.io/images/9040391713089174625.jpg)
![](https://cdn.hackaday.io/images/8837161713089174684.jpg)
![](https://cdn.hackaday.io/images/5529841713089174732.jpg)
![](https://cdn.hackaday.io/images/2245761713089174697.jpg)
![](https://cdn.hackaday.io/images/2461891713089174739.jpg)
![](https://cdn.hackaday.io/images/9897701713089174854.jpg)
The final product:
![](https://cdn.hackaday.io/images/5143051713089303304.jpg)
![](https://cdn.hackaday.io/images/1080381713089307470.jpg)
![](https://cdn.hackaday.io/images/4151271713089310934.jpg)
![](https://cdn.hackaday.io/images/4379191713089315833.jpg)
![](https://cdn.hackaday.io/images/9946001713089316225.jpg)
![](https://cdn.hackaday.io/images/8881231713089317081.jpg)
![](https://cdn.hackaday.io/images/8799801713089317401.jpg)
![](https://cdn.hackaday.io/images/8615961713089318599.jpg)
If you have any questions about the build process, please feel free to get in touch. There is still some work to be done - the motor mounts need redesigning, the enclosure needs improved waterproofing, and I would eventually like to add some lights to the board.
