At quantity (20 pcs) the cost works out to approximatly $4 per channel. That's not bad.
A project log for Dual 12bit SPI 4-20mA Converter
The title says it all. This is a dual 12bit SPI 4-20mA output driver to be used to create analog outputs for current outputs.
